02-26-2017, 02:30 PM | #1 |
flexplate question
I am installing a TH350 in place of the original 3 speed manual in my 64. What diameter of flex plate will I need. The old flywheel measures 14" outside diameter but the 14" flexplate I installed is too big, I cannot bolt the starter up
Thanks |
02-26-2017, 06:20 PM | #2 |
It's Better With Nitro
Re: flexplate question
Double check the tooth count...and, you may have to shim the starter now.
02-26-2017, 06:50 PM | #3 |
153 tooth standard flywheel and starter might bolt up But different through
from auto to manual . BBC use 168
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
