1961 Crossmember Swap Question
Hello,
I am starting to swap in a 1986 cross member and was curious about the current hydraulic clutch setup. Has anyone performed this swap and what do you do with the current clutch/brake master cylinder setup? I will be using the booster out of the 86 Silverado. Thanks for your help, Josh |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 1961 Crossmember Swap Question
This is what I have to offer.
http://www.67-72chevytrucks.com/vboa...d.php?t=362375 But the '73-'87 boosters are not compatible with any of my booster brackets. You would have to use one of the many, many compatible boosters.
