Old 02-27-2017, 09:53 AM   #1
Alberta355
First 4x4
After having probably 6 or7 2wd squares i figured it was time for a 4wd. Unfortunatly i lost my phone halfway thru rebuilding it so i lost quite a few photos but hopefully ill be able to recover them to share
The first few pics are of the day i bought it,it hadint left the farm in 18 years and definently needed some love. I had to throw a old carb i had on it and limped it the 1.5 hour drive home
Alberta355 is offline   Reply With Quote
Old 02-27-2017, 10:10 AM   #2
Alberta355
Re: First 4x4
Its a 1981 gmc sierra classic 4x4 with a 350/350 combo ,the box was rusted out so the previous owner swaped it for a very nice fairly strait box.As i am a bodyman/painter by trade i did not want to get carried away with the bodywork and paint because i want to drive the **** out of it and not have to worry about a littld scratch so gravel guard and spray balms it is, i spent less than $250 on the paintjob and the flat colors really hide the dents and rust pits quite well, a gallon of rust mort and fibreglass later here inwhat i came up with
Old 02-27-2017, 10:22 AM   #3
Alberta355
Re: First 4x4
Next up was the wheels.i found a set of bf goodrich 33s for a steal at $300 for all 4 from a local listing with about 70% tread, after a quick paintjob on a set of old rallys i had kicking around the wheels were goood to go.the second pic is on a hoist and thats what it would look like with a 3.5 inch lift ,next up is that gutless old 350
Old 02-27-2017, 01:53 PM   #4
daddyjeep
daddyjeep's Avatar
Re: First 4x4
I like what you did with the wheels. They really tie into the truck nicely.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 03-12-2017, 10:23 PM   #5
JoeinT.O.
Re: First 4x4
I really like that as well. Very nice. I can't quite make out what you painted on the fenders. What is it?
JoeinT.O. is offline   Reply With Quote
Old 04-28-2017, 07:07 AM   #6
Alberta355
Re: First 4x4
Thought id do a bit of a update as its been almost two months since i started this thread and four since i started the truck.
I cleaned up the old 350 put a cam,headers,and a carb on it, still seems terribly gutless unfortunatly so im thinking i may drop in a 350 i have built up for my wrangler matched up with a 700r4, it looks great though
Old 04-28-2017, 07:16 AM   #7
Alberta355
Re: First 4x4
I dont know why my pics keep loading upside down heres a few more, the last two are after i put in the 3 inch lift kit that got it sitting just how i wanted it.
Old 04-28-2017, 07:47 AM   #8
Alberta355
Re: First 4x4
Got to playing with the dash the other night as it was getting pretty dim and i think i have the worst dashpad known to man, i painted the backsides of the cluster neon orange aswell as the pins then clearcoated the guages and im very hapy with how it turned out, ill have to take some pics at night it glows orange and looks awesome.
Old 04-28-2017, 08:08 AM   #9
LT7A
Re: First 4x4
I like the truck and the utility approach to making it look cool. What did you use to clear coat the gauges?
Old 04-28-2017, 08:11 AM   #10
Alberta355
Re: First 4x4
Also got a bush bumper for the front i added holes for the signal lights and welded in some nails for a grill for the lights
Old 04-28-2017, 08:16 AM   #11
Alberta355
Re: First 4x4
I just used a spray balm clear, it was tricky cleaning the guages because the white paint comes off very easily even with a damp cloth
