02-27-2017, 07:40 PM | #1 |
Help with installation of 1965 driveshaft bearing - which way?
I am working on a 1965 C10 2WD with a two piece driveshaft. I just purchased a new bearing from LMC Trucks and it arrived with no instructions and an 'extra' small bushing?? The bearing can be removed from the rubber housing with a little work.
The rubber bearing has a sealed side "A" and an open side "B". Which is the proper way to press on this bearing (picture A or B)? What is the use of the small bushing that came with this? Searching previous posts did not provide the info I am looking for. Any help, as always, is sincerely appreciated. Mark |
02-27-2017, 07:58 PM | #2 |
Moderator
Re: Help with installation of 1965 driveshaft bearing - which way?
I'll guess A is correct, and not sure on the bushing. Looking forward to the solution!
