Old 02-27-2017, 08:42 PM   #1
fatblockvelle
fatblockvelle's Avatar
1966 c10 when gauge cluster help.
When I plug in the cluster (was unplugged when I got it) the volt gauge stays pinned and fuel gauge works all the time. Even with the key off. I can only imagine that's why they had it unplugged. Everything works.... charges... fuel gauge... temp.... just when it's plugged in it stays pinned on charge.... any ideas what could be doing that? Something giving the cluster power all the time? The wiring is all original and does not look very molested. Thanks. Jesse
1970 chevelle
1971 blazer
1972 c20 custom camper
1931 ford A coupe.
fatblockvelle is offline   Reply With Quote
Old 02-27-2017, 08:51 PM   #2
PGSigns
PGSigns's Avatar
Re: 1966 c10 when gauge cluster help.
The amp gauges have a habit of burning up. It could be smoked. The fuel gauge gets power when the key is on so something is back feeding it. With more than 50 years of PO's not many suggestions on where to start except to clean up everything you can that looks like it was added.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-27-2017, 08:56 PM   #3
fatblockvelle
Jimmy
This just in... when I start the truck the gauge goes down a little but the truck does not shut off. Until you unplug the cluster..... I just unplugged the volts gauge and everything works with the key and shuts off with the key.
1970 chevelle
1971 blazer
1931 ford A coupe.
Old 02-27-2017, 09:34 PM   #4
CRUZN66
CRUZN66's Avatar
A voltmeter is wired differently than an ammeter so make sure of which gauge you actually have so you know which way to wire it.
CRUZN66 is offline   Reply With Quote
Old 02-27-2017, 10:50 PM   #5
fatblockvelle
Unplugged the volt gauge ....everything works as it should
1970 chevelle
1971 blazer
1931 ford A coupe.
Old 02-28-2017, 07:45 AM   #6
PGSigns
PGSigns's Avatar
They had amp meters in them so has someone added a volt meter?
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 02-28-2017, 08:01 AM   #7
fatblockvelle
Jimmy
Sorry I was talking about amp gauge.
1970 chevelle
1971 blazer
1931 ford A coupe.
