03-08-2017, 05:53 PM | #1 |
Van Tilt
Clean tilt with nice levers and cancelling cam. No problems.Needs cleaning/paint. $200 and shipping.Please respond in the post. First take it gets it.
03-08-2017, 05:54 PM | #2 |
Re: Van Tilt
22222
03-08-2017, 05:54 PM | #3 |
Re: Van Tilt
33333
03-08-2017, 05:55 PM | #4 |
Re: Van Tilt
44444
03-08-2017, 05:56 PM | #5 |
Re: Van Tilt
55555
03-08-2017, 05:57 PM | #6 |
Re: Van Tilt
66666
03-09-2017, 05:00 PM | #7 |
Re: Van Tilt
$225 shipped. Also for sale locally.
03-11-2017, 10:39 AM | #8 |
Re: Van Tilt
Bump
03-11-2017, 03:51 PM | #9 |
Re: Van Tilt
PM sent
03-11-2017, 04:34 PM | #10 |
Re: Van Tilt
$150 shipped?
03-13-2017, 08:22 AM | #11 |
Re: Van Tilt
Bump.
03-13-2017, 11:06 AM | #12 |
Re: Van Tilt
This will fit a '71 with a 3speed? If i use a floor shifter? Can I just get a delete plate of some sort for the shifter on the column? @uncle
03-13-2017, 11:30 AM | #13 |
Re: Van Tilt
The only way I've ever seen it made into a floor shift column is to grind off the area where the shifter goes and fill it in with something. The upper bowl will also move where the shifter was if not locked in place but I guess that would be a matter of personal preference.
03-13-2017, 11:56 AM | #14 |
Re: Van Tilt
Can you take some more pics of it, specifically where the shifter goes...doesn't seem like too big a job to make it work for my application, assuming the ball socket for it is nice and tight im interested...
03-13-2017, 12:03 PM | #15 |
Re: Van Tilt
The tilt mechanism is tight. Not sure what you're looking for as far as pictures but here's a few more. There will also be two screw holes when you take the indicator off and you may want to shave the pointer area but that's up to you.
03-13-2017, 12:04 PM | #16 |
Re: Van Tilt
22222222
03-13-2017, 12:05 PM | #17 |
Re: Van Tilt
3333333
03-13-2017, 12:06 PM | #18 |
Re: Van Tilt
4444444
03-15-2017, 03:33 PM | #19 |
Re: Van Tilt
Bump.
03-16-2017, 03:30 PM | #20 |
Re: Van Tilt
$200 shipped.
03-18-2017, 11:24 AM | #21 |
Re: Van Tilt
Bump
03-18-2017, 03:41 PM | #22 |
Re: Van Tilt
What's the difference in the van and truck column ? Will this fit 69 Chevy c10?
03-18-2017, 03:45 PM | #23 |
Re: Van Tilt
The length of the shaft at the bottom which can be fixed by collapsing your intermediate shaft. Location of the neutral safety switch. Also have to add both rubber and metal pieces that mount column in truck but can be done by bending shift lever and not dismantling.
03-18-2017, 03:46 PM | #24 |
Re: Van Tilt
Yes it will fit in the truck
03-20-2017, 07:41 AM | #25 |
Re: Van Tilt
Bump
