Old 03-12-2017, 02:16 AM   #1
Dragun12
Dragun12's Avatar
Building The Grip Monster
I've had my truck for 8 years now and I drove it hard for 6 of them and more miles than the odometer could count and being that I'm a fabricator by trade i figure I'm going to go all out and build a road racing grip monster on a tight budget
Dragun12 is offline   Reply With Quote
Old 03-12-2017, 02:22 AM   #2
Dragun12
Dragun12's Avatar
Re: Building The Grip Monster
Big block 454 and Muncie m22 with hurst v gate shifter
Old 03-12-2017, 02:27 AM   #3
Dragun12
Dragun12's Avatar
Started the tare down and I'm going to be putting quad empi epc 48s on the big block just got one for now, I plan on fabricating my own manifold later
Old 03-12-2017, 02:31 AM   #4
Dragun12
Dragun12's Avatar
I'm going to make a wide body fiberglass one piece front clip and I'm going to run 335/30r18s all the way around
Old 03-12-2017, 02:34 AM   #5
Dragun12
Dragun12's Avatar
I'm going to take this rearend and cut axle tubes off and make it and IRS fab 9
Old 03-12-2017, 10:55 AM   #6
RDrancher
RDrancher's Avatar
Watching this one.
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 03-12-2017, 11:24 AM   #7
GR8-68
GR8-68's Avatar
Interesting, I am in for the ride
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 03-12-2017, 12:21 PM   #8
Devil Pup
Devil Pup's Avatar
Can't wait to see how this shapes up
Devil Pup is offline   Reply With Quote
Old 03-12-2017, 03:53 PM   #9
Rod Run
Rod Run's Avatar
Curious to see how this one goes
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 09-17-2018, 07:59 PM   #10
Dragun12
Dragun12's Avatar
Ok it’s been a long time since I’ve posted I’m still building the truck things have shifter a little bit from race truck to more daily driver it’s still getting a big block 489ci but efi not Weber’s. It’s getting a auto gear m22w still going to run the v gate shifter and I’m going to keep the 12 bolt rearend just upgrade it. it is on bags and it going to get a short bed conversion. I am currently running 335/30zr18 all the way around. It’s going to get a step side bed with the rear fenders widen about 5” on each side and I’m going to go steel fenders up front I wanted to do fiberglass but steel will last much longer
Old 09-17-2018, 08:22 PM   #11
Dragun12
Dragun12's Avatar
Some more pictures sorry for the odd camera angles it just uploaded them that way
Old 09-17-2018, 10:27 PM   #12
MoFormula
Love this build.
MoFormula is offline   Reply With Quote
Old 09-17-2018, 11:19 PM   #13
jadedbird
jadedbird's Avatar
Those wide stepside fenders are going to be thicc
jadedbird is offline   Reply With Quote
Old 12-30-2018, 05:47 AM   #14
Dragun12
Dragun12's Avatar
Ok it’s been a long time since I’ve done a update mainly because not much has happened but I’ve got a 489 stroker kit for it and decided to go twin 72mm turbos and I did the short bed conversion on it as well and again the iPhone doesn’t like to upload pictures right
Old 12-31-2018, 04:15 PM   #15
Sparky dave
I’ll be following I’m wanting to fabricate a twin turbo kit for my 350 using a Fitech or equivalent fuel injection
Sparky dave is offline   Reply With Quote
Old 01-02-2019, 02:41 AM   #16
Dragun12
Dragun12's Avatar
Did a little work to the truck got the cab back on the truck and skinned fenders for the wide body and played with grill ideas and where and how I’m going to mount the turbos
Old 09-07-2020, 08:39 PM   #17
Dragun12
Dragun12's Avatar
Ok update time. I’ve got some parts that should make the truck a better driver but also handle better. I’ve decided to keep the truck carbureted and Naturally aspirated just to keep it simple. Also got rid of the m22 rock crusher and I’m now running a tko600. Also I’m going to be putting in a rear suspension out of a 2010 camaro ss using a kit from animals speed shop.
Old 09-07-2020, 08:48 PM   #18
Dragun12
Dragun12's Avatar
More pictures
Old 09-08-2020, 05:51 AM   #19
72 tigger
72 tigger's Avatar
Nice progress! Going to be nasty
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 09-08-2020, 09:08 AM   #20
Low Elco
interesting! I'd like to know more about that rearend kit.
Low Elco is offline   Reply With Quote
Old 09-10-2020, 10:12 AM   #21
SCOTI
SCOTI's Avatar
Tagged-in.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-30-2020, 12:42 AM   #22
Dragun12
Dragun12's Avatar
Ok I got a chance to do some work on the truck and get some parts installed and almost installed still a long way to go
Old 11-30-2020, 12:04 PM   #23
SCOTI
SCOTI's Avatar
That 'new rear set-up' seems to have influenced things toward the opposite end of the truck.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-30-2020, 12:59 PM   #24
Dragun12
Dragun12's Avatar
Naw I always wanted a more of a pro touring truck and for a little bit I lost my way. But now I’m back on track
Old 02-28-2021, 07:51 PM   #25
Dragun12
Dragun12's Avatar
So I’ve got the rearend all tack welded in and the rear wheels just barely fit over the calipers. The front not so much. So out with the 18s and in with 20s
