Old 03-15-2017, 05:27 PM   #1
1978sierra
Horn Part Info needed
My horn used to work, then one day it stopped. I noted that when I changed the ignition lock cylinder and was putting the wheel back on I depressed the plunger on the canceling cam with the screwdriver and got a pretty big spark... I think that was when it stopped working.
Anyway, I wanted to get it working again so started to tear down the column, when I got to the turn signal switch I found a chard and small bit of copper where the plunger and spring are supposed to be, I yanked it out with some pliers.
Now I am trying to find the part # for that plunger and spring but am coming up short. Can anyone help.
Here are some pictures:
1978sierra is offline   Reply With Quote
Old 03-16-2017, 07:24 AM   #2
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Re: Horn Part Info needed
I believe they used to sell that part in the Help section of the auto parts stores.
http://www.oreillyauto.com/site/c/de...1&keyword=horn
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 03-18-2017, 08:28 PM   #3
Pontiac1976
Pontiac1976's Avatar
http://www.ebay.com/itm/Turn-Signal-...FYqnmh&vxp=mtr this the part your looking for, order in non tilt. & tilt set up. LMC has them too / Classic Parts 73-87 / As said Dorman help scction
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
copper, horn, turn signal switch
