04-05-2017, 03:42 PM | #1 |
engine angle question
hi all,how many degrees is too much?my engine seems to be sitting at 6 degrees.
i have poly engine and trans to bellhousing mounts.i'm not sure how i could shim to lessen the angle.at the top of the carb it seems to be about a degree and a half. thanks for any help...dan |
04-05-2017, 04:01 PM | #2 |
Re: engine angle question
Usually the goal is ~3* from between the tailshaft and diff. My assumption is that there is no cant in a transmission, so if your engine is 6* the tailshaft will be 6*. There should be some flex in the mounts, so I'd guess that the easiest solution would be to shim the transmission up a few degrees.
But other more knowledgeable people will likely chime in soon . |
04-05-2017, 04:12 PM | #3 |
Never Ending Projects
3-4* is about normal. Some intakes have a angle to the carb mount so you can just get this level and it puts it around that angle. To raise yours up, assuming you have clearance for the trans, figure out how much you need to lift the back of the trans to get the desired angle and then cut a piece of flat stock and put it between the trans and the mount.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
04-05-2017, 04:15 PM | #4 |
thanks a lot guys.i will give that a try.
04-05-2017, 08:00 PM | #5 |
well,i shimmed the trans up a bit but i don't think i'm going to reach the 4*goal
without getting too close to the cab floor.i am wondering if the prothane motor mounts are a bit thicker than stock? anyone else run into this? |
04-06-2017, 10:37 AM | #6 |
Not sure they are any thicker but I think they compress less that factory rubber ones.
04-06-2017, 10:45 AM | #7 |
what trans do you have?
what condition are your cab mounts and any rust concerns in your floor? ron |
04-07-2017, 05:21 PM | #8 |
Trans is a t5,floor is pretty solid, Cab mounts are a bit soft and need to be replaced so that's a very good point !thanks for pointing that out
That could very well make the difference of the trans going up a little bit more |
