Old 04-11-2017, 09:47 AM   #1
56hotrodred
Which fuel sender
I have to order fuel sender and of course it needs to match the fuel guage! My question is it seems most of the aftermarket gauge kits for 56 Chevy are 0-30 ohm. Are the 0-90 ohm units any better? I could get the dash insert and buy a 0-90 ohm 2 1/16 inch fuel and other gauges separately.
I do think the dash insert with all gauges installed will be less expensive. I also am planning on going with the ramjet 350 so don't know if that matters for any of the other gauges that may come with the complete unit.
56hotrodred is offline   Reply With Quote
Old 04-11-2017, 12:58 PM   #2
1project2many
Re: Which fuel sender
The sender resistance must match what the gauge is expecting. A 0-90 Ohm unit would show "full" around 1/3 tank with a gauge designed for 30 ohms.
The Ramjet engine computer does not talk to the gauges.
I'd suggest picking your gauges first, then making sure you have the correct sender for each gauge.
1project2many is offline   Reply With Quote
Old 04-11-2017, 02:02 PM   #3
HUSSEY
HUSSEY's Avatar
If you go with a dash insert consider the Speedhut gauges. Their fuel gauge is programmable so it works with any sender.
For my truck I bought New Vintage gauges which wasn't compatible with my 0-90 ohm sender in my S10 tank. I wanted to used the sender/fuel pump assembly for the gauge in the tank so I had to pay New Vintage to convert the gauge.
http://www.speedhut.com/?_vsrefdom=a...FZO4wAodVqcBRQ
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 04-13-2017, 12:11 PM   #4
01spirit750
56'
My understanding is that the 0-90 ohm gauges are more accurate than the 0-30 ohm gauges.
If you can get a matched set 90 ohm gauge and a 90 ohm sending unit, I would.
The issue you will have is retrofitting a 90 ohm sending unit to a stock tank.
01spirit750 is offline   Reply With Quote
Old 04-13-2017, 01:09 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
GM gauges up to about 1964 use a 30 ohm after 64 use a 90 ohm. swapping a 90 for a 30 will give you a false reading.
dwcsr is offline   Reply With Quote
Old 04-13-2017, 01:38 PM   #6
56hotrodred
Hey thanks for the responses...
First off I am going with aftermarket gauge cluster with there being more 0-30 ohm replacement dash inserts with matching gauges and I have replaced the stock tank to the rear frame position.
I have also read that the 0-90 ohm units are more accurate but as said there appears to be more choices of gauge clusters and matching senders in the older style 0-30 ohm.
Now I know so can pick a sender.
Thanks all!!!
