Old 04-11-2017, 11:49 AM   #1
rwdmayhem
Custom brake lines
Has anyone used this type of brake line from Russel? http://www.jegs.com/i/Russell/799/632510/10002/-1 or know of any other stainless steel braided brake hose?
rwdmayhem is offline   Reply With Quote
Old 04-11-2017, 01:00 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Custom brake lines
I have used them, Earls and another brand I can't recall. I always get mine pre assembled or have my local shop make them and pressure test them. Personally, I would never do my own build of these lines for brakes. Too much at risk if they fail due to incorrect assembly.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-11-2017, 01:54 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
If they don't say DOT in the add don't waste your money.
Old 04-11-2017, 03:55 PM   #4
rwdmayhem
I take it you just get them from the factory hard line to the caliper/drum?
Old 04-11-2017, 05:29 PM   #5
chevy_mike
chevy_mike's Avatar
Yep, used them for places the factory rubber ones go. You do NOT want to plumb your whole system with flex line. You want to keep flex lines to the minimum you can, otherwise you will end up with a spongy pedal.
