Old 04-21-2017, 12:03 PM   #1
Mr_T
Oil Change for Manual Transmission and Differentials
Unless I totally missed it the manual doesn't show a quantity of oil needed for the differentials, transfer case, and manual transmission when changing the oil, only to use a GL-5 90W.
Anybody done this service and could enlighten me how much oil I need to be buying? I have a '78 GMC K15.
1978 GMC K15, Sierra Grande
Mr_T is offline   Reply With Quote
Old 04-21-2017, 12:12 PM   #2
Tash4
Tash4's Avatar
Re: Oil Change for Manual Transmission and Differentials
2 qts for diff & 2qts for np205 t-case. im not sure on trans.
Tash4 is offline   Reply With Quote
Old 04-21-2017, 04:02 PM   #3
Bears63
...just another truck junkie..
Bears63's Avatar
The '78 Owner's Manual says 4 qts for the SM465 and between 1.5 and 2 qts for the various 3 speeds.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 04-22-2017, 01:34 AM   #4
kwmech
The 465 will take a gallon, the 205 will take 2+ quarts, the rear diff, complete drain and refill 2+. All of these you fill to the bottom of the fill hole. Pickup 2 gallons and 2 quarts unless it's cheaper to buy 3 gal.
Old 04-22-2017, 04:39 PM   #5
tucsonjwt
SM 465 takes 1 gallon of 80-90. I would check for leaks before you change the transmission oil. You might have leaks at the PTO covers and need new gaskets, so an empty trans is the time to replace them.
tucsonjwt is offline   Reply With Quote
differential, transfer case, transmission fluid
