04-22-2017, 12:42 PM | #1 |
What uses a fuel dampener and what for?
I saw a reference to "fuel dampener vs fuel regulator" in another post, didn't want to randomize that thread, so:
What's a fuel dampener for, what cars have one? I'm assuming it takes out (absorbs) the pressure drop pulses from injectors firing, but since lots of cars don't have one, curious about when they added them, to what they added them, and so on. I know nothing, tell me everything!
04-22-2017, 02:18 PM | #2 |
Post Whore
Re: What uses a fuel dampener and what for?
Maybe this'll explain it..http://injector-rehab.com/shop/fpd.html
04-22-2017, 02:20 PM | #3 |
Post Whore
04-23-2017, 12:58 AM | #4 |
meowMEOWmeowMEOW
AFAIK it was mainly the early Fbody and Ybody cars that had FPD's. Its the extra "thingy" when looking at Fbody vs normal returnless fuel systems. It is not "needed" and if your running a good pump and factory FPR, the ECM fueling should handle any change created by the injectors draining down the rail.
Its usually something you'll see on higher-performance factory variants of cars, where the needed injector duty cycle causes draindown on the rail ahead of what the pump is supplying @ rail pressure. IMO its a factory bandaid.
