84 c10 to 04 2500hd conversion
Decided to combine my two trucks today into one. Body donor 84 c10. Frame and drivetrain donor 04 Silverado 2500hd ex cab shortbed with a 6.0.
Re: 84 c10 to 04 2500hd conversion
Looks like a productive day. Any pics of how it all went together? I assume you had to build some body mounts.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
That's a surprisingly nice fit! Were there any frame length mods done?
Ya I was kinda in a hurry to get it done so I didn't get too many pics and I'm having trouble uploading them. I had to cut the extended cab frame and I sectioned in a reg cab long bed frame. I had already solid axle swapped it so I spliced frame where the old torsion bar mounts were built a plate that bolted there and welded it. There are two holes on frame that line up perfectly with front cab mounts so I sat mounts on them and used long threaded rod to go through frame and into cab. I just redrilled radiator support for front mounts. Had to build crosdmember for rear mounts.
Looks good!....late model driveline and classic looks=winning!!
Ya it's actually not a very hard conversion. I did my 85 shortbed last year on an 06 2500 frame. That one is still ifs drives far superior to any 4wd squarebody I've ever owned. Then I built a turbo kit for it just to give it a little get up and go. But this one was done on a budget used factory harness and fuse block to make it super simple to wire.
This was the reason for the body swap. Too much throttle?
