Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 05-01-2017, 01:10 PM   #1
tex_waco_usmc
Project Heaven in my 67!!!
Ls swap donor...what's needed?
I just recently acquired an 01 2500hd with 6.0 and 4l80 tranny. What all do I need to pull off the donor truck to do the swap. Momma doesn't want this truck sitting in our driveway long(body is very rough)! Please help don't want to get rid of anything I'll need.
tex_waco_usmc is offline   Reply With Quote
Old 05-01-2017, 02:29 PM   #2
nastety92
Re: Ls swap donor...what's needed?
Engine
Engine wiring harness
Transmission
ECM / PCM
Gas Pedal
Air Intake if your going to use the stock one
Might as well keep the fuse block under the hood
Overflow tank
Mechanical fan if your going to run that
On my swap I'm trying to make it look 100% stock under the hood. Other people have done custom air intakes and electric fans.
Also is the truck going to be 4wd or 2wd in the end?
Good luck,
Nick
nastety92 is offline   Reply With Quote
Old 05-01-2017, 02:42 PM   #3
tex_waco_usmc
2wd in a short bed 67. Do I need cross members, etc?
Old 05-01-2017, 02:42 PM   #4
nastety92
Is the 2500HD 2wd or 4wd?
Old 05-01-2017, 02:53 PM   #5
t300
If you really want to get everything you can off it it then add throttle cable, cruise control box and cable, rear view mirror and temp sensor/wiring, I used a bunch of the exhaust piping to build my exhaust as well. 7pin trailer wiring, hitch may be able to be used. Saw a post here where someone used the rear brake calipers with a custom bracket. Apparently door molding can be used. Some have used the front bench seat or buckets.
t300 is offline   Reply With Quote
Old 05-04-2017, 09:15 AM   #6
tex_waco_usmc
2wd
Old 08-09-2017, 10:28 AM   #7
lynnfield
The Waco Kid
lynnfield's Avatar
There's some info in here from when I did my swap. Its a lot to read thru, but it may be some help. Greg
http://67-72chevytrucks.com/vboard/s...d.php?t=585899
lynnfield is offline   Reply With Quote
Old 08-15-2017, 09:35 PM   #8
boynton
boynton's Avatar
I also used the cats but my donors were low mile. The lead offs might be nice at least to get the exaughst started.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
