Old 05-05-2017, 08:32 AM   #1
kx57
'66 front wheel well rubber/metal cover below air cowl vent
So on our '66 C10 there is a area where the front wheel well/inner fender/cab/fender all join at the bottom.
See this picture. (this isn't our truck..but shows the spot)
Left hand side of the photo.
When you put the fender on there is an area here that looks like it would easily collect dirt/debris.
What is supposed to cover this area?
-I don't see anything on LMC truck other than the air vent cowl..this is below that...
-I don't see anything on image searches that indicates there is anything there to cover the void....
Does anyone have any photos of this area with the fender installed?
I did a few forum searches..I can't find anything for this vintage that shows what I'm talking about. Lots of threads about welding up the air vents..but that isn't what I'm looking at.
kx57 is offline   Reply With Quote
Old 05-05-2017, 09:54 AM   #2
scoot_mcgrute
Re: '66 front wheel well rubber/metal cover below air cowl vent
What area are you looking at exactly, can you circle it in paint and re post the picture?
There are these pieces but I don't know if this is the area you are talking about. These go off the fender between the mounting bolts near the cowl and door.
http://www.classicparts.com/1960-66-.../#.WQyDSk11qpo
http://www.classicparts.com/1960-66-.../#.WQyDsU11qpo
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 05-05-2017, 10:00 AM   #3
chevylookin
Are you referring to the closing panels that attach to the inner fender brace? I dont think that LMC has those but but the Truck Shop in Orange has the complete installation components for our trucks:
http://www.ebay.com/itm/1960-1961-19...-/302046406217
chevylookin is offline   Reply With Quote
Old 05-05-2017, 10:23 AM   #4
vin63
It's Better With Nitro
vin63's Avatar
There isn't anything that covers that channel between the firewall and cowl. The fender has a tab that locates in between.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-05-2017, 11:33 AM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Oh VIN you beat me to it. That pic is awesome, it's exactly what is needed.
Old 05-06-2017, 04:55 AM   #6
kx57
I'll get a picture and post it. Might not be until Monday...have to see when I can get over to the garage.
Old 05-15-2017, 07:09 AM   #7
kx57
Okay so here is what we currently have :
[IMG][/IMG]
Old 05-15-2017, 08:33 AM   #8
CRUZN66
CRUZN66's Avatar
You need all the following:
http://www.classicparts.com/1960-66-.../#.WRmdQlRMGf0
http://www.classicparts.com/1960-66-.../#.WRmdgFRMGf0
http://www.classicparts.com/1964-66-.../#.WRmduVRMGf0
http://www.classicparts.com/1960-66-.../#.WRmeYFRMGf0
http://www.classicparts.com/1960-66-.../#.WRmejlRMGf0
http://www.classicparts.com/1960-66-.../#.WRmevVRMGf0
http://www.classicparts.com/1960-66-.../#.WRme21RMGf0
http://www.classicparts.com/1960-66-.../#.WRmfUFRMGf0
(need 12 of these clips)
http://www.classicparts.com/1960-66-.../#.WRmfeFRMGf0
CRUZN66 is offline   Reply With Quote
Old 05-15-2017, 08:58 AM   #9
kx57
Awesome! Thanks for the help.
When I was searching online I was having a hell of a time finding any photos that show this area. Especially ones that show the individual pieces being installed/pulled out.
