05-23-2017, 09:28 PM | #1 |
Drive shaft for '65 long bed.
I'm to the point that I'm fixing to get driveshaft made for my ,'65 LWB. First question is, being a long bed, do I have too make it a two piece (like the original truck) or can I make a one piece. The truck has 2.5" drop spindles in front and, 2" drop springs in the back. Also, what kind of price should I expect to pay. Of course I know that the kind of metal that is used and, whether or not its one piece or two will make a difference.
Thanks in advance! |
05-24-2017, 12:12 AM | #2 |
Re: Drive shaft for '65 long bed.
I've got a 66 long bed and I'm in the same boat, no usable driveshaft. Pricewise, I have no idea as differant shops will be differant prices.
A 2 pc driveshaft will be stronger than a single long driveshaft, the single may have a tendancy to wobble in the unsupported middle unless it's of a very large diameter. Unless modified, the trailing arm mount crossmember where the driveshaft goes through won't accept a shaft that big. Since you are having one made, I have it made in the HD carrier bearing version. The LD mount hangs from above the driveshaft and the HD carrier bearing mounts under the driveshaft.
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
05-24-2017, 10:04 AM | #3 |
Moderator
If I was building a LWB and didn't have a shaft, and especially if it was modded... I would take a shaft from a late model LWB/extended cab and have it shortened and have the shop put the correct conversion yokes on it. Those new shafts are beautiful big aluminum pieces. You need a good driveline shop that can do aluminum shafts. Most cities have truck driveline shops.
05-24-2017, 11:37 PM | #4 |
60-66 Nut
The bad reputation of the 2 piece driveshafts stems from the light duty 2 piece version, which I would never use. On a long bed I would use a HD 2 piece driveshaft with the HD carrier bearing. With that said, it is much less money to have a driveshaft shortened than is it to have one lengthened or a complete new one made.
