Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 05-30-2017, 02:04 PM   #1
Nobighurry
Help finding wheel cylinders on 1970 C60
Hey guys - I'm having the brakes redone on my C60 due to a couple leaky wheel cylinders. I was able to find one of the from the casting number at NAPA, but no luck on the other one. I can't find the 19105 cylinder. I found plenty of the 19108. Anybody run into this before? Do you have cross reference numbers? My truck is a heavy medium with Dayton's. I'm looking specifically for the rears.
Thanks!
Nobighurry is offline   Reply With Quote
Old 05-30-2017, 08:43 PM   #2
rkn463
rkn463's Avatar
Re: Help finding wheel cylinders on 1970 C60
Thanks!
Give Geoff at Alretta Truck Parts (alretta.com) a call. He knows more about old truck brakes than anyone else I ever came across.
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 05-30-2017, 09:49 PM   #3
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I have a few books, there's listings for different axle capacities. I don't show the 19105 in any Bendix or Wagner book I have, the 19108 shows up though. Is your truck a tandem axle or single? And does it have one wheel cylinder per side, or an upper and lower?
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 05-31-2017, 09:39 AM   #4
Nobighurry
Thanks to both of you for your quick reply. Upon further cleaning and inspection, I feel pretty confident that both the upper and lower and the same 19108 wheel cylinder. The last digit on one of this wasn't stamped deep or maybe it was just caked with junk, but it could pass for a 5, 6, 8 or 9. Visual comparison of the two cylinders show that they look identical. THe fact that the 5 doesn't exist, I've ruled that one out. The 9 has a different bore (1 3/4 vs 1 5/8) so I'm leaning against that one. I really believe the two are the same. I picked up a couple rebuild kits just in case.
I'll let you know how it goes.
