Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 06-11-2017, 07:39 PM   #1
greywuuf
Ok ..seriously i need help
Does anyone know if an H70 with power steering has any kind of a fluid cooler or a check valve or anything in line between the pump and the steering box?...I just replaced the pump, which was obviously bad as the vanes were all scattered about the inside.....however the new pump does not seems to be doing ANY thing.. fluid level did not even drop when I fired it up. ....pulled the lines at the box and no fluid...... Lines plugged? It is not bypassing like it is making pressure .......what have I missed ?
greywuuf is offline   Reply With Quote
