06-12-2017, 11:54 AM | #1 |
parts from 67 250 3 speed cheap!
Finally getting a chance to work on my 67 & first thing to do is to pull the original 250 engine & 3 speed trans. Going with a 350/350 combo so any parts related to the engine or trans or shift linkage r available. The engine was smoking so its going to the scrapper, but anything attached to it is available.
As per board rules I am listing a few parts but please lmk if there is anything u r interested in. All parts will be cheap! (u pick up the ride) - carb (ran but needed choke closed) $15 - air cleaner $5 - valve cover $5 - distributor, coil, wires $10 - alternator $5 - engine stands $10 - shift linkage $10 - 3 speed trans $40 (no shipping) - clutch linkage $25
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
06-12-2017, 12:32 PM | #2 |
Re: parts from 67 250 3 speed cheap!
I'll take the carb , air cleaner and alt, shipped to 37938
06-12-2017, 12:59 PM | #3 |
grumpy, its 95 out today & tomorrow so wont be able to pull parts towards end of the week. I will get back 2 u on total with shipping once parts r pulled & boxed.
Scott
06-12-2017, 01:01 PM | #4 |
Thats fine just let me know when your ready to ship ,Thanks
06-12-2017, 05:29 PM | #5 |
How about the exhaust manifold shipped to 32803, business address?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
06-12-2017, 06:04 PM | #6 |
FL71c10, will check on shipping & let u know once I get it pulled.
06-12-2017, 06:16 PM | #7 |
great, thanks. Mine is real bad.
I get a discount on shipping thru my company. If you give me the dimensions and weight, I can email you a shipping label. Thanks.
06-16-2017, 02:44 PM | #8 |
Grump, looks like shipping will run around $20 via fedex.
If that's ok I will PM u payment info, can do PP or MO. FL71C10, haven't had a chance to put the manifolds but should soon. Will let u know once pulled & boxed. Scott
06-16-2017, 02:53 PM | #9 |
Yeah , I'm still in I just sent you a pm .
06-16-2017, 09:45 PM | #10 |
Hello, I'll take the engine pulleys, clutch linkage and shift linkage and distributor. Shipped to 37303.
Thanks |
06-16-2017, 09:58 PM | #11 |
waylonbud, give me a couple of days to pull everything & box them up.
Will get back 2 u on total. Scott
06-17-2017, 05:00 AM | #12 |
Sounds good, no hurry.
06-17-2017, 07:44 AM | #13 |
06-19-2017, 05:41 PM | #14 |
waylonbud, here r pics of the parts, shipping will run $20 via fedex.
I will take $5 off of clutch parts as I didnt pull the clutch fork, so total is $60 shipped to ur door. If thats ok PM me & I will send u my payment info. FL71C10, pulled the intake/exhaust but doesnt look like I will be able to separate them easily. If u still want both manifolds lmk & I will find a box for them. Keep in mind these r not light, and a strange shape, so box may be fairly big. Would like to get $40 for the combo. LMK Scott
06-19-2017, 07:48 PM | #15 |
Sounds good, just get me the dimensions and we'll figure out shipping. Please just make sure there are no cracks in the exhaust manifold.
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. Last edited by FL71C10; 06-19-2017 at 07:57 PM. |
06-20-2017, 09:28 PM | #16 |
Pm sending your way.
Thanks |
06-21-2017, 08:02 PM | #17 |
just checking to see if you made any progress with the manifolds yet?
06-21-2017, 11:38 PM | #18 |
Actually I found a box today that should work.
I will get back to u tomorrow with the info. Scott
06-22-2017, 12:02 PM | #19 |
FL71C10, sending u a PM with the info.
Did not c any cracks.
06-22-2017, 01:49 PM | #20 |
Paypal and UPS label sent
06-27-2017, 12:14 PM | #21 |
I got the manifold today. Thanks!
06-27-2017, 12:34 PM | #22 |
odd question hope you can help I have a 67 just got it I cannot find the brake switch can you take a pic of yours so I can try and find it. I cannot even find loose wires. Thanks in advance if you can help
06-28-2017, 12:27 AM | #23 |
Does the valve cover say chevrolet and do you still have the engine accessory brackets thanks
06-28-2017, 12:28 AM | #24 |
06-28-2017, 03:41 AM | #25 |
Any chance you still have the shift lever from the column side?
