Old 06-27-2017, 08:22 AM   #1
74CustomK20
74CustomK20's Avatar
Question Pulling front end?
Hey guys need some insight. I'm going to the wrecking yard this weekend to pull a doghouse for my 98 k2500 diesel off a 96 suburban. Any idea what I'll need to pull it? I'm taking literally from the cab forward. Radiator core support etc. I've done many square body but the obs bodystyle is new to me.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 06-27-2017, 02:47 PM   #2
abig84
abig84's Avatar
Re: Pulling front end?
hopefully someone else can answer better but my 1990 when i wrecked it like 7 yearrs ago you pretty much just needed a ratchet and a 1/2 and 9/16ths socket and extensions to get the majority of the bolts off.
you also have two big body mount bolts going through the core support, i think its 3/4 inch bolts but not sure. but its a nut and bolt combo so make sure you bring some box end wrenches.
so i would think if you brought a good socket set with a nice selection of box end wrenches you will do fine.
just seen your from indiana, so expect rust and bring a pair of vise grips as some of the welded nuts that the bolts go through are likely to snap and spin
abig84 is offline   Reply With Quote
Old 06-27-2017, 03:40 PM   #3
74CustomK20
Yea that's why I'm get this front clip. Mine has the fender flares and behind them it's complete rust. This suburban looks good...I planned on taking my impact and socket set. I plan on picking up a set of metric wrenches. Figure 98 it'll be metric.
Big Nate
Old 06-27-2017, 04:39 PM   #4
Pampas56
The easiest way I found to get the body mount bolts for the rad support out was a 15MM socket on a breaker bar above and 18MM deep socket on a 1/2" ratchet below. Don't skimp on the WD40/PB Blaster.
Most of the rest are smaller bolts and wiring clips. You will spend more time removing stuff from the inner fenders than anything else.
A decent socket set and screwdrivers will do most of it. A good cordless drill or impact will make it go quicker.
Steve
1989 Silverado K2500ECLB- 307K miles with 90 K TBI 350-Not a show truck, a work tool that I can drive!
1998 Dakota EC 250K miles- I guess I'm just a truck guy now!
Pampas56 is offline   Reply With Quote
Old 06-28-2017, 07:33 AM   #5
74CustomK20
Awesome. So it shouldn't be too bad. The ones on my rust loved 98 the only thing that even looks solid is the core support... Almost like it's been replaced before... Anyway glad to know most common tools will get it.
Big Nate
front end, pull a part
