Old 07-12-2017, 10:43 AM   #1
Nodnarb76
Nodnarb76's Avatar
AC/heater control unit bulb
Is there anything I should know about replacing my AC/heater control unit bulb?
When I unscrew and pull the unit from the dashboard I worried something will come off and recoil inside my dash, or I may break something.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 07-12-2017, 12:56 PM   #2
Breeze454
Breeze454's Avatar
Re: AC/heater control unit bulb
When you take the gauge bezel off, you should be able to get to it through the A/C vent hole, no need to take the A/C controls out. I've also taken out the lower A/C duct (under the steering column) and reached up into the dash and replaced it.
Breeze454 is offline   Reply With Quote
