08-23-2017, 08:18 PM | #1 |
Bought a C7000- Anyone help?
So I bought a 1986 GMC C7000 last weekend. On the way home, the left rear brake seized, rotor got red hot and ended up catching fire. The rotor broke into several pieces and welded itself to the pad. I was able to put it out and limp it home, but now I am in the middle of doing the rear brakes on it. Can anyone identify the rear end for me? It would help in ordering the parts.
1976 Chevy 1/2T 2wd SWB 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com |
08-23-2017, 08:19 PM | #2 |
Re: Bought a C7000- Anyone help?
Carnage pics for your viewing pleasure.
08-23-2017, 09:16 PM | #3 |
I think it's 17,500 axle with oil bath bearings if that helps and anyone can give me advice on them.
08-23-2017, 10:25 PM | #4 |
At the body shop.
" That didnt make it any newer " " Dont antique the equipment " |
08-23-2017, 10:54 PM | #5 |
My rotor doesnt have the flange, it's 2 piece instead. I'm looking at the code in the glovebox and its code H93: Rear axle GMC 175 SG. Im surprised how little info is out there on these trucks. That code is pulling up on rockauto though so I might be sorted now.
08-23-2017, 11:39 PM | #6 |
https://www.brakepartsinc.com/raybes...rt-search.html
You'll have to enter your trucks information, they show a lot of parts for that one. Seems like they go by the size of the caliper pistons and the rotor diameter, not by the brake/axle code for some reason.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
08-24-2017, 12:58 AM | #7 |
Thanks. Does anyone know what oil to use for these bearings? What about where to pick up some of these conical washers? What a pain. If anyone ever has issues with them, just double nut the stud and pull it out, the cone washers will loosen up pretty quick. The axle was sealed with RTV, is this where the outer wheel bearing seal would typically go? I havent found one tearing this thing apart but there is a listing for one.
08-24-2017, 08:51 AM | #8 |
I won't be much help. I didn't even know those newer trucks had Rear Discs !!
Big jump from my '62 GMC days. Air Brake, Rear Only, Drum Brakes (No Fronts).
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
08-24-2017, 06:39 PM | #9 |
IIRC, the oil from the differential works its way down the tubes and that is what lubricates the bearings. Should be a seal on the back side of the hub and no "outer" seal. Where the axle bolts to the hub is usually just a paper gasket (or RTV).
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
08-25-2017, 01:36 AM | #10 |
Thanks, yeah thats what I read somewhere else. I will change the diff fluid while I'm in there and I should be good to go.
09-12-2017, 11:01 AM | #11 |
Why did it seize? I have had several trucks with these brakes, usually the rubber hoses deteriorate internally and hold pressure after brake application.
09-12-2017, 12:11 PM | #12 |
At the body shop.
We always packed a bit of grease into the the bearings.
At least dunk them in gear oil prior to assembly.
09-15-2017, 07:54 PM | #13 |
"Tapered dowels" are what they're called in old Mitchel manuals, also "axle stud cone"...I know they can be fun to get out, that's for sure. Looks to be several options including NOS GM ones on ebay: http://www.ebay.com/itm/like/2630527...=ps&dispItem=1
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
