Old 10-16-2017, 04:04 PM   #1
Root2812
Root2812's Avatar
Hooker manifold and starter issue.
So I purchased some manifolds from Hooker.
https://www.holley.com/products/exha...arts/8501-3HKR
I am running into a few problems and questions. When I went to put them on the right side manifold hits the starter heat shield. They say the manifolds fit my 2000 5.3L engine so I am not sure why they would be rubbing. I took the heat shield off since I am just in the mock up phase and now the manifold fits. Can I run without the heat shield or will I have problems later? Will I need a mini starter?
I am running an f-body pan and dipstick, which the manifolds should clear but they don't. I think I can bend the dip stick a little though.
Has anyone else run into these problems with the hooker manifolds and what did you do?
Thanks.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 10-16-2017, 04:50 PM   #2
truckdude239
truckdude239's Avatar
Re: Hooker manifold and starter issue.
those are basliccy the same as the tbsss manifolds should clear, i wouldnt run without the heat shied
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 10-17-2017, 09:10 AM   #3
Steve Cole
Wow, I thought those were supposed to fit everything. Sorry I can't help but this is good to know as I was probably going to buy these. Keep us posted how this turns out and good luck!
Steve Cole is offline   Reply With Quote
Old 10-18-2017, 12:39 PM   #4
Nodnarb76
Nodnarb76's Avatar
I used those manifolds when I did my swap. I replaced my starter with a new AC Delco starter when I did my swap also. I have no rubbing issues, the manifolds and starter fit fine. Are you using an aftermarket starter?
Now that I think about it, my new starter did not come with a heat shield, and the old rusty starter I took off didn't have one either. FWIW, I have about 9,000 miles on my truck now and have never had a problem with the starter with a missing heat shield.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 10-18-2017, 11:02 PM   #5
72MARIO
72MARIO's Avatar
I may not be much help but the 6.0 starters are bigger than the 4.8 and 5.3. That might give you the clearance you need.
I am using a 5.3 starter on my 6.0 and it been fine for a year.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 10-18-2017, 11:21 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I didn't know the starter even had a heat shield. My '66 hasn't had one for the 15k ish on it.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-23-2017, 11:07 PM   #7
Root2812
Root2812's Avatar
Thats good to know. I took the small clip on heat shield off for now and it seems to be fine for fit. If you guys aren't having problems then I won't worry about it any more.
Just incase I am not calling it by the right name here is a pic i found online. The clip on metal shielding on the top of the image is what I am talking about.
My 1950 Chevy build
