Old 11-27-2017, 11:37 AM   #1
DrppdBlazr
DrppdBlazr's Avatar
Anyone ever Use the Spectra Premium Oil Pan?
Anyone ever Use the Spectra Premium Oil Pan GMP77A on here for thier LS swap? It looks the same as the Chevy Performance #12628771. If you look at the Napa website and Search for the Chevy Performance 12628771 it comes up with this Spectra Pan. I get a good discount at napa and was going to go with this pan, just wanted to know if anyone knew any information on it before i bought it.
https://www.napaonline.com/en/p/STPGMP77A
Here is the Link to the Pan im talking about... Thanks for the help
Bodied Blazer Build
http://67-72chevytrucks.com/vboard/s...d.php?t=611842
DrppdBlazr is offline   Reply With Quote
Old 11-27-2017, 11:56 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Anyone ever Use the Spectra Premium Oil Pan?
That looks like the Dorman F body pan, which I would think it probably is, just repackaged. You can get it at summit for like $199. Never used it before, but do know you will need the F body pick up tube to go along with it, you can probably cut down a windage tray to work though.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-27-2017, 11:57 AM   #3
verdell
verdell's Avatar
This is the oil pan I planned on using myself. I won't start the actual swap until January tho. I'm pretty much sold on this one.
verdell is offline   Reply With Quote
Old 11-27-2017, 01:44 PM   #4
DrppdBlazr
DrppdBlazr's Avatar
Yea I can get this one with my Discount from napa for $145. I will probably end up getting new Pick up tube and Windage tray from napa as well if they carry those as well as the dipstick tube and dipstick
Bodied Blazer Build
Old 11-27-2017, 10:40 PM   #5
Clrussell
Clrussell's Avatar
Why not get the "muscle car" from gm performance parts? $209 comes with everything
61 apache
Clrussell is offline   Reply With Quote
Old 11-27-2017, 10:41 PM   #6
Clrussell
Clrussell's Avatar
http://www.jegs.com/i/GM-Performance...0aAivwEALw_wcB
61 apache
Old 11-28-2017, 12:59 AM   #7
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
That's pretty much a truck oil pan. Hangs down a few inches more
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 11-28-2017, 02:07 PM   #8
Clrussell
Clrussell's Avatar
I gotcha. I looked at the napa link just now
61 apache
Old 12-01-2017, 08:06 AM   #9
PGSigns
PGSigns's Avatar
You need to look at how long the sump is on the NAPA and make sure it is not to long and wont clear the crossmember. It does look like an F body pan. The GM performance pan is about an inch shorter than the truck pan.
Jimmy
A good link with pan measurements.
https://www.improvedracing.com/tech/...dimensions.php
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-01-2017, 10:50 AM   #10
NC_John
NC_John's Avatar
For what its worth, the holley pan (302-1 or -2, need to check) fits fantastic. I can get my hand between the crossmember and the pan and there is plenty of clearance. And you can get an optional road-race baffle kit for it to keep the pump from starving under "spirited driving."
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
