11-28-2017, 10:25 PM | #1 |
Can't find the correct fitting.
I'm in a real bind here. Trying to connect the power steering line from the box to the pump and can't find the right fitting. I've been to Home Depot and True value and no luck. I've attached two pictures. The fitting on the left is the one that is in the pump, I removed it to take with me to stores. The fitting in the middle comes off of the steering box and attaches to one end of the line. The fitting I need will connect the fitting on the left(on the pump) to the line on the steering box.
Thanks Last edited by '65 chevy lover; 11-28-2017 at 10:30 PM. |
11-28-2017, 11:19 PM | #2 |
Re: Can't find the correct fitting.
Try NAPA.
11-29-2017, 12:29 AM | #3 |
But Found Her 25yrs Later!
I found that farm supply stores have a huge selection of fittings.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
11-29-2017, 12:45 AM | #4 |
60-66 Nut
Do you have a local business that specializes in hydraulics? That is where I would go. You can also find it at Summit Racing. They have a new warehouse in Arlington TX.
11-29-2017, 01:36 AM | #5 |
Thanks to all for the replys. I'll check them out. I saw the Summit place about a week or so ago and had planned on going by there just to check it out. Now I have a reason to go there besides just to look around...lol
11-29-2017, 11:44 AM | #6 |
Never Ending Projects
Just so you know what to look for, you are going from an inverted flare (not sure on size) to a AN fitting (looks like a -6 in the pic). This will help you narrow what you are looking for.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
11-29-2017, 02:35 PM | #7 |
Like chevy mike said. Go to summit and take the pump fitting. Inverted flare to pump fitting AN to hose as was stated. Summit carries all these type of fittings.
1961 chevy K10 my build is------------61K10 build |
11-29-2017, 02:44 PM | #8 |
Looks like you need an inverted flare to fit the power steering and an AN or JIC fitting for the hose. Can't tell what sizes from the picture. Note that the difference between AN and JIC are the material that the adapter is made of- AN is aluminum and JIC will be steel. Otherwise, they should interchange. I agree with the above statements- NAPA if they carry hydraulic hose and fittings or any other place that makes hydraulic hoses. Summit may carry them as well. Inverted flares are not used so much in AN stuff- that is what brake lines are but that is going to be bigger than common brakes. You will have better luck with steel fittings from hydraulic hose makers.
11-29-2017, 04:56 PM | #9 |
Man you need a Parker store!
Please note that even though AN & JIC are the same dimensionally most places don't speak AN but do speak JIC. Measure the diameter of your fittings & I can tell you what number they are. |
11-29-2017, 07:38 PM | #10 |
Thanks again for all the help! First place I went was to the new Summit Racing store. They had the fitting I needed, plus some stuff that I needed but had forgotten about! LOL Man, I could spend 1/2 day in there just wondering around and dreaming..LOL
11-29-2017, 10:13 PM | #11 |
what year is your pump from and what year is your box. are you trying to go from metric to sae. just take the fitting from the same year as the box( this is the fitting that goes into the back of the pump). should solve the problem
rom |
11-29-2017, 11:10 PM | #12 | |
sounds like you've got it handled..
here's some info for future reference, good luck! Quote:
I started out with nothing - and I still have most of it |
11-29-2017, 11:44 PM | #13 |
Thanks again to all for the information, it's much appreciated!
