1953 Stock Tank EFI Fuel Pump
I have a 1953 3100, S10 frame with a 5.3l with the stock in-cab fuel tank and would like to install a in-tank fuel pump that meets the need of the early (return style) 5.3l. I searched and didn't find what I was looking for - are there and kits anyone know of for a conversion?
I could do an external pump, but the potential noise and the need to install a return line could be avoided. Thoughts? Links to previous forums I missed in my search?
It was said that if you cut off one hydra head, two more grow back. -Lernaean Hydra Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=743246 |
Post Whore
![]() ![]() Join Date: May 2015
Re: 1953 Stock Tank EFI Fuel Pump
not sure if there's anything that would work without a lot of fab work and rigging....im sure it can and has been done though...I'm running external walbro 255 pump and its not loud..if you mount it under the cab I doubt you'll ever hear it unless you have really quite mufflers...adding a return line to your sender would be fairly simple....but my 2cents would be advise you to ditch that incab tank..and go with a boyds or similar style tank...
I've seen several threads where people have added intank pumps. ..maybe they'll chime in
I have seriously considered an aftermarket tank, but with how I have everything I’m not sure where I will have space. I don’t want it in the bed, so I thought since I have one I would use the cab tank to get it up and running and relocate tank later.
That’s good to know those Walbro pumps are quiet, that was one I had looked at. Just considering different options.
Post Whore
you'll get a lot of opinions on what quite is...the only time I can hear mine is when I turn the key on before cranking...once engine is running its a non issue for noise...the boyd tank mounts between the frame rails behind the rear axle....you can getem with the intank pump....
An in tank pump inside your cab will be way louder than an external pump mounted on the frame. I have a stock tank and the Walbro 255 and just like Mongo said you can't hear it.
I just had 2 bungs welded into a stock tank. One for fuel and the other for return. You may be able to use the stock pickup tube for a return but I was concerned about it possibly messing with my gas gauge. |
I know the under bed mount tank like what was used on the 47/48’s is available again.
There are all kinds of evil fuel pump conversion kits out there. Might be something to look in to. |
I will stick with my original external pump, and if I can fit it I'll look into a between frame tank later on.
Thanks for all the advice.
