4L80E Cooler line size 3/8" or 5/16"
Who has put a 4L80E into their truck, and what size cooler lines did you use. Seems the later 4L80E transmissions used 3/8" lines and I am wondering if its safe to use the stock 5/16" cooler lines with the 4L80E.
1968 SWB Step Side, Big Block, 4L80E , Running! |
I'm just glad to be here!
Re: 4L80E Cooler line size 3/8" or 5/16"
3/8 is what we used.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
![]() Join Date: Dec 2012
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
meowMEOWmeowMEOW
In general for almost any automotive system; bigger lines can be used in place of smaller lines (fuel, oil, trans, coolant etc). Smaller (narrower) lines in almost any of those systems will create a restriction point, and depending on which system, will have different negative effects; cavitation, reduced flow, increased pressure where pressure is not desired, foaming, increased heat.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Ditto.
Have found that GM used 5/16" cooler lines on the 4L80E until 1998. They must have gone to 3/8" when they moved the return line to the middle of the transmission case. All the radiators I have found for my 67 to 72 truck have 1.2" - 20 threads for 5/16" cooler lines so there will be some restriction at the radiator even if I run 3/8" lines to it. Thinking about splitting at the radiator and adding an aftermarket cooler in parallel to keep the flow up. Since GM ran 5/16" lines on the 4L80E in the early years I assume that unless I work the transmission hard I would be ok even if I stayed with the 5/16" lines.
