Old 12-19-2017, 05:31 PM   #1
chuckmc8
It's alsways something.....
chuckmc8's Avatar
2002 L59 Flex Fuel OK for swap?
I have done quite a few swaps but none with L59 flex fuel option. The engine I am considering is a 2002 L59 with low miles
Is there any special consideration for the flex fuel option as it relates to an engine swap?
I read that there is a sensor that measures the amount of ethanol in the fuel and adjusts accordingly- and that the PCM defaults to a standard setting if the computer does not get a reading from the sensor.
Is this something that is addressed in the PCM tuning?
I will just use regular pump gas as always and do not need the flex fuel capability but do not want to throw a code that puts on the check engine light
Thanks for suggestions
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 12-19-2017, 07:20 PM   #2
qwik
qwik's Avatar
Re: 2002 L59 Flex Fuel OK for swap?
I did one, no issues at all.
qwik is offline   Reply With Quote
Old 12-20-2017, 12:06 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Honestly it seems worth it to just get the sensor from a donor and hook it up. Its not an immensely complicated piece, and allows you to run 87-93 straight, low-E blended (common) gas, and E75,85,90.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
