Old 12-28-2017, 07:06 PM   #1
CG
BlahBlahBlah
Burb lift gate cables instead of brackets?
I feel like someone had replaced the lift gate brackets/arms with cables on their burb and did a thread about it, but I'm not finding a thing. Anyone?
Old 06-03-2018, 12:37 PM   #2
kev2809
low n' slo
kev2809's Avatar
Re: Burb lift gate cables instead of brackets?
im not sure where the link is but u can screw in the little ball studs that mount the gas pedal? been a while...but they screw in where the old lift arms go..then u mount a gas strut in its place. ill see if i can find it..
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 06-03-2018, 03:30 PM   #3
CG
BlahBlahBlah
Ive seen those done for the barn doors and the hatch, but not the gate
Old 06-03-2018, 03:37 PM   #4
kev2809
low n' slo
kev2809's Avatar
found it...
http://67-72chevytrucks.com/vboard/s...d.php?t=220511
-_--_--_ _________
Old 06-03-2018, 03:40 PM   #5
ahlsy
ahlsy's Avatar
I just installed a gas strut kit from Brothers on my lift gate. If it wasn't for one screw that wouldn't give up, the whole thing would have been done in 5 minutes. Very easy install, and they work awesome. Just unlatch the gate, and it rises up to the top on its own. No lifting,or bouncing the gate at the top to make sure both mechanical latches are engaged...
The kit was nice and saved some measuring, but it would be easy enough to take a few measurements and source the gas struts and ball pivots separately.
ahlsy is offline   Reply With Quote
Old 06-03-2018, 07:04 PM   #6
CG
BlahBlahBlah
I have the parts for what I call the hatch, the upper part with the glass in it. Got them using the posted link. Thanks for posting it up, excellent thread for those that missed it first time around.
I was looking for info on the drop down tail gate.
Old 06-04-2018, 08:50 AM   #7
Hart_Rod
Hart_Rod's Avatar
CG - I did this to my suburban. I think there are quite a few pictures in my build thread and the part number for what I used.
Rob
Hart_Rod is offline   Reply With Quote
Old 06-04-2018, 10:18 PM   #8
CG
BlahBlahBlah
Thanks Rob, I bet that was the one I saw.
Old 06-04-2018, 11:21 PM   #9
kev2809
low n' slo
kev2809's Avatar
ah yes totally missed that. i plan on doing the same exact thing..i threw those side hinges away a long time ago lol
-_--_--_ _________
Old 06-05-2018, 08:29 AM   #10
Hart_Rod
Hart_Rod's Avatar
I think the ones I used are off of a mid-90s truck, but they don't appear to be any different than the ones on my 2017 Silverado...
Old 07-21-2018, 11:27 AM   #11
Burb
Coordinator of Synchronicity
Burb's Avatar
Make sure you measure where you want your gate to sit
Before mine was torn down had a set off a newer chevy truck gate cables and they were a had short for my liking and you had to sometimes hop up to sit on the gate depending on where the rear bags were at
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
