Old 12-30-2017, 06:20 PM   #1
Afirehawk1
66 c10 Rear Cross Sill
Does anyone know where the spot welds should go on the rear cross sill?
Afirehawk1 is offline   Reply With Quote
Old 12-31-2017, 02:00 PM   #2
61K10
61K10's Avatar
Re: 66 c10 Rear Cross Sill
Mine was welded on each bed side. did not re-weld when i put the bed back together. This was a fleetside. Others have said no need. Heavy loads probably.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 01-01-2018, 04:16 PM   #3
oldusafmsgt
oldusafmsgt's Avatar
Fleetside rear bed crossmembers were welded to the bedsides. Like 61K10 said, really no reason to weld them unless doing a 100% factory restoration.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
Old 01-01-2018, 09:05 PM   #4
rideblue00
rideblue00's Avatar
Bolts should be tight or the sides will drift out of square, mine did
rideblue00 is offline   Reply With Quote
Old 05-25-2020, 11:52 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Somewhat related question, how hard was it to remove the rear cross sill from the bedsides?
66 C20 Service Truck:
Old 05-26-2020, 01:08 PM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
Step-side?
Old 05-26-2020, 03:58 PM   #7
LostMy65
LostMy65's Avatar
Fleetside
Old 05-26-2020, 06:16 PM   #8
DPowers
DPowers's Avatar
My experience is there is a weld across here that can be a pain to get to.
DPowers is offline   Reply With Quote
Old 04-04-2022, 09:59 PM   #9
LostMy65
LostMy65's Avatar
I'm not sure how i forgot about this thread. Thanks for the reply. I'll get the bolts out and then cut away at the weld. i'll try to take some pics.
