I'm in the process of replacing my timing cover seal for 04 Tahoe engine that will go into my 68. Just wanted to know if anyone has a recommendation on how to install it with out damaging when the cover is put onto the engine? I've seen the tool online but i was hoping i wouldn't have to buy it. Is it possible to install without the alignment tool or is it best to buy the tool? If i do need the tool which do you guys recommend? Thanks
Re: 04 Tahoe Timing Cover Seal Install Help!!
You need the tool to align it since there are no alignment dowels on the cover. I have put them on loose before though, then installed the balancer/crank pulley, then tightened the cover with good results.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
A guy with a truck
What he said. Press on the balancer, give it a spin, then tighten your cover bolts
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
