Junior Member
![]() Join Date: Dec 2017
4l60e to np205 a little easier
Im about to begin my swap using a 6.0/4l60e out of a 2001 yukon denali. Has anyone used these two parts from advance adapters? First is a 6 bolt to four bolt adapter with a vss. Part # 50-0405. http://www.advanceadapters.com/produ...onadapter-kit/ The second is a spacer to take up the shaft length. Part #50-8505. http://www.advanceadapters.com/produ...with-gm-700r4/ Ive got the parts sitting on the shelf in the shop. This will put the T-case into the stock position and move the motor forward a bit. Other than having to trim the trans shaft about a 1/2 inch its bolt in. Ive seen this bolted together on a friends rig, but yet to go down the road.
![]() Join Date: Mar 2004
Re: 4l60e to np205 a little easier
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
I the six to four bolt adapter, short output shaft. Then used the stock cost iron mount.
