01-10-2018, 10:03 PM | #1 |
air conditioning and fuel tanks
I have read thru some great threads and have gained a ton of knowledge, sometimes too much, on swapping to a 4.8 lq4 engine. I'm sorry if i have overlooked a thread on this. My 69 c10 is an ac cab truck and the 4.8 i am installing has a brand new ac compressor that i would like to reuse. I'm not in a position to put a retro system in and am wondering if anybody has used the ac pump from a ls to work with the 69 ac box. The ac worked great before i removed the 350 and i have capped all the lines and fittings so no moisture would enter.
Also I want to move the gas tank under the bed between frame but have the fuel fill come out behind license plate like on my 70 chevelle, and install a flip down plate. Any body make some suggestions with sender and intake fuel pump? Thank you in advance. |
01-11-2018, 01:17 AM | #2 | |
Re: air conditioning and fuel tanks
5.3 = LM4 6.0 = LQ4 I think lol People have done what you are wanting and will chime in. It’s tedious work, custom made fittings/hoses etc.
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
01-11-2018, 01:44 AM | #3 |
I started out with nothing - and I still have most of it |
01-11-2018, 11:38 AM | #4 |
You can use the newer pump with the older factory AC components.
J.R. Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010 Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer |
01-11-2018, 12:48 PM | #5 |
Sorry gmc. Stupid auto correct. Thanks. I have a guy who makes lines for a living so that's no biggie. Seeing as old compressor only had 1 wire newer one had 6 I think
01-11-2018, 12:56 PM | #6 |
The PCM can control the newer AC, on/off, dile high, high speed clutch etc. Or you can wire it standalone.
