01-18-2018, 08:55 AM | #1 |
Swap Radiators
I'm rapidly getting closer to the point where I am going to have to decide on a swap radiator. I want all the hoses on the passenger side and sold my original rad months ago so that isnt an option.
Looking at all the usual suspects, entropy, r&d, coldcase, etc.... It needs to cool a 600 hp mill with A/C. Don't need a transmission cooler. Has anyone found anything that makes one better than another? I want made in the US so i think that knocks out coldcase. Is anyone using Spal fans? They all look similar online and pricing is pretty close too. Anyone else I should be considering? Thanks
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
01-18-2018, 09:52 AM | #2 |
Re: Swap Radiators
My RND cools engine great with a.c. the transmission cooler sucks first ride out it ran 220f. Way too hot. That was empty. I sent him a email and no response.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-18-2018, 10:20 AM | #3 |
Re: Swap Radiators
Can you identify what brand fans they use?
01-18-2018, 03:39 PM | #4 |
Re: Swap Radiators
I got a cold case with fans so far so good motor runs around 198 degrees
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
01-18-2018, 06:03 PM | #5 |
Re: Swap Radiators
What made you pick them over the others?
01-18-2018, 07:46 PM | #6 |
Re: Swap Radiators
I went cold case, mainly for two reasons. Stamped tanks and it was cheap. I worry about the cheap part because as you know you get what you pay for, but just looking at it I see no issues with it, so maybe it will be a good deal.
I found an aluminum fan shroud on ebay I hope to retro fit to my radiator and I plan on running Spal fans. Not radiator specific but on fans. I ran into a problem with mine where I wanted a high flow Spal. I looked online and never really saw a fuse rating that it called for so I figured Id order it anyhow and go from there. I got it and it called for a 40 amp fuse. Not a big deal if you go direct to the battery but my LS harness has everything already built in, but fused to 30 amps. I want to use this part of my harness to keep things clean and orderly so I had to send that fan back and will probably end up with something a little less flow under 30 amps. Something to consider depending on how you are going to wire your fans. |
01-19-2018, 12:04 AM | #7 |
Re: Swap Radiators
I didn't buy fans I used stock clutch fan. The only time my truck gets to 195 is pulling our 25" camper up longgraded with the a.c. on. I habe a delco thermostat 195 in it. Most of the time.it runs 185-190
01-19-2018, 02:53 PM | #8 |
Re: Swap Radiators
John,
I believe that RnD, along with pretty much every other radiator company uses imported or "non-branded" fans unless they specifically state otherwise. Not to say that they won't install whatever fan you want, (if you pay for it) and as long as it fits their shroud holes, (they might). You could also just buy the radiator and blank shroud and fit your own fans to it. or, go with something like this: https://www.summitracing.com/parts/s...8aAthbEALw_wcB Old Air Products also has a nice dual SPAL fan/shroud combo if you are okay with the plastic shrouds. In my opinion, the new Entropy LSX radiator with the aluminum fan mount brackets is the sexiest radiator/fan combo on the market. To see a real good picture of it, go to their website and look at the one for the 69 Camaro, they have a better pic for that one. It's very pricey, over $1000 for that with the controller. Ouch! The Engineered Cooling Products radiators are their import line and look to be well made and a whole lot cheaper. Griffen fans are US made I believe but the reviews are not very flattering. I still can't decide what to do myself, so let me know what you end up doing, and I will buy it from you in two months when you change your mind.LOL |
01-20-2018, 08:13 AM | #9 | |
Re: Swap Radiators
I'm already prepared to pay around $1000 to get what I want, just want to make sure for that money I make the right choice.
01-20-2018, 11:37 AM | #10 |
Re: Swap Radiators
I picked cold case cause of price and a life time warranty it was 425buxs for the radiator Nd fans dont know what brand the fans are but they move some air just make sure to ask for a radiator cap and they will inculde it for free so they say i didn;t know that when i ordered mine so i used the on off my old giffren ls radiator they died after onyl 3 years of use
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 01-20-2018 at 11:55 AM. |
01-20-2018, 12:30 PM | #11 | |
Re: Swap Radiators
01-21-2018, 07:33 AM | #12 | |
Re: Swap Radiators
I think cold case is out for me. I do want a rad made here. Thanks!
01-21-2018, 07:36 AM | #13 | |
Re: Swap Radiators
01-21-2018, 07:38 AM | #14 | |
Re: Swap Radiators
Ok, thanks.
01-21-2018, 07:45 AM | #15 | |
Re: Swap Radiators
I thought you bought a fan at goodguys or autofair?
01-21-2018, 10:48 AM | #16 |
Re: Swap Radiators
Yes, our radiators are made to fit in the stock hangers. They fit with the 3 core or 4 core rubber inserts.
And, we never use any plastic, glue or epoxy in any of our radiators |
01-22-2018, 01:52 PM | #17 |
Re: Swap Radiators
Guys, if anyone has any tech questions about our Cold Case radiators or cooling issues in general, feel free to post or PM me. We're here to help.
01-22-2018, 01:56 PM | #18 |
Re: Swap Radiators
Cheap is a relative term! Keep in mind I have been giving C10 Forum members special pricing. The retail price of our fully polished, dual 1 1/4" tube units are just under $400. It's not an entry level radiator by any means.
01-23-2018, 12:30 AM | #19 |
Re: Swap Radiators
You might look at Wizard cooling in upstate NY. No epoxy, all USA. I've seen them in person at a couple of shows - nice work. Lots of options and unlike most companies their shrouds do not look like an afterthought. They use Maradyne as well as Spal fans and their website has lots of straight forward information - virtually no hype.
https://wizardcooling.com/1967-1972-...inum-radiator/ |
01-23-2018, 04:41 PM | #20 | |
Re: Swap Radiators
01-23-2018, 09:18 PM | #21 |
Re: Swap Radiators
The BeCool 35202 fits well.
01-23-2018, 09:39 PM | #22 |
Re: Swap Radiators
Looks good but why the center mount bracket up top? Did it not fit in the factory mounts?
01-23-2018, 09:42 PM | #23 |
Re: Swap Radiators
That is an altered factory mount. My truck is a '65.
01-23-2018, 10:10 PM | #24 |
Re: Swap Radiators
Ahhhhh... Ok. Didn't catch that in the pics.
01-23-2018, 10:52 PM | #25 |
Re: Swap Radiators
