01-19-2018, 09:47 AM | #1 |
Rear end gears???
What rear end gear to run with a 4L70E and LS3 500hp???
OLDIRONRACING |
01-19-2018, 10:55 AM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Rear end gears???
Depends on tire size and what objective you have, speed or driver.
Normally a 3.42:1 is the go to! But a 3.73:1 is what I run with my 4l60e.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-19-2018, 12:02 PM | #3 |
Post Whore
use a rpm calculator to determine what you need. ...one like this. ...http://www.csgnetwork.com/multirpmcalc.html
01-19-2018, 02:27 PM | #4 |
I'm going 3:73 in my C10 with 4L60E and 27-28" tires.
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
01-19-2018, 02:56 PM | #5 |
I will also be using 3:73:1 in my stock 5.3 / 4L60E combo.
01-19-2018, 03:38 PM | #6 |
In my 1968 truck I have the 12 bolt truck rear. It seems limited to either 3.08, 3.73 or 4.11:1. There might be some on the extreme ends I don't remember but I have not found the 3.42 or others in that range. You may have a different rear end so you may have those options. I am running 3.73:1 my trans is a 4l80 so it is geared a little different.
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
01-19-2018, 05:11 PM | #7 |
I'd go with 3:73 if you're starting from scratch. I have that in my Blazer with a 6.0 and its a nice gear. My Green truck with the 5.3 has the factory 3:08 posi and I feel like it hurts it a bit, just a little too tall of gear for the overdrive.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
01-19-2018, 09:22 PM | #8 |
meowMEOWmeowMEOW
3:73 is the one-size-fits-all recommendation for swaps IMO, especially since the 12 bolt variation is fairly common, and if you switch rear ends staying with 3:73 is easy across the board. I run it in my 12 bolt and its quite good behind my 6.0
01-20-2018, 10:59 AM | #9 |
I'm using the 12 bolt that came in it just going to rebuild it. The 3:73 gear was what I'm thinking. Tire size is up in the air don't know what will fit or look good. Want to put as much tire as I can (width) Thinking a 18 or 20 tall rim. Don't like that rubber bad look for tires.
OLDIRONRACING |
