Old 01-19-2018, 08:52 PM   #1
statenine
statenine's Avatar
power steering hose question
Hey all, I am in the process of doing an LS swap (2010 5.3), and currently have manual steering. I will be upgrading to power steering at the same time and need help determining the correct pressure and return hoses to use. I have a 1970 C10 power steering gearbox (remanufactured by Cardone), and the 5.3 already has a pump on it. Will these hoses work?
https://www.speedwaymotors.com/Unive...hoCgboQAvD_BwE
statenine is offline   Reply With Quote
Old 01-19-2018, 09:49 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: power steering hose question
The LS steering pump is metric. The steering gears were SAE and a few went metric later in production.
You'll either run a line with the correct ends, or you may be able to swap the fitting on the rear of the steering pump. There are a few threads about doing so in this section.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-20-2018, 12:09 AM   #3
statenine
statenine's Avatar
Something like this?
https://www.dirtydingo.com/shop/mobile_product_info.php?products_id=1414
Old 01-20-2018, 01:15 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
You can use this:
http://www.jegs.com/i/Russell/799/648060/10002/-1
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-20-2018, 11:27 AM   #5
truckdude239
truckdude239's Avatar
The easliest way i know to do this is go to the junk yard find an old chevy early 70s to late 70s and steal the 1 inch fitting and spring and vavle out of it then swap it to the new ls pump and use the stock lines for you truck thats what i did on my 71 c10 that why if hose ever breaks i can just get on at the parts store
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-20-2018, 11:30 AM   #6
truckdude239
Look at this thread http://67-72chevytrucks.com/vboard/s...d.php?t=627585
David fuller
2000 Tahoe 5.3l 378
Old 01-20-2018, 05:07 PM   #7
ls1nova71
ls1nova71's Avatar
https://www.dirtydingo.com/shop/mobi...oducts_id=1414
Yes, that would work if you have your factory hoses still, but I like the option below better.
This is what I would do, although you maybe shouldn't steal the fitting from the junk yard. LOL!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
