Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-21-2018, 11:35 PM   #1
Mack B
Mack B's Avatar
Cutting up 65 cab
Cab is rusty in all the usual places, but if you happen to need an uncommon piece or section I may can help you out. I just don’t want to scrap anything that someone may be able to use. $15.00+shipping per section. I’ll gladly take pictures of anything you need, if you see any thing else of interest just ask. I will probably not be able to cut any areas until weekends. Thanks for looking!
Mack B is offline   Reply With Quote
Old 01-21-2018, 11:40 PM   #2
DPowers
DPowers's Avatar
Re: Cutting up 65 cab
Sail panels?
DPowers is offline   Reply With Quote
Old 01-22-2018, 12:22 AM   #3
Mack B
Mack B's Avatar
Originally Posted by DPowers View Post
Sail panels?
There is one, but the finish on it is horrendous. I don't think its salvageable.
Old 01-22-2018, 12:59 AM   #4
ScottH
ScottH's Avatar
can u post a pic of the center hump?
thanks
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 01-22-2018, 01:03 AM   #5
pimpston65
pimpston65's Avatar
how bout both A pliars? can you cut the whole section from the bottom hinge hole area down. including both inside and outside the cab?
pimpston65 is offline   Reply With Quote
Old 01-22-2018, 01:12 AM   #6
pimpston65
pimpston65's Avatar
all this area.
Old 01-22-2018, 09:32 AM   #7
MikeG.
Dash ?
MikeG. is offline   Reply With Quote
Old 01-22-2018, 11:49 AM   #8
Mack B
Mack B's Avatar
Originally Posted by pimpston65 View Post
all this area.
Absolutely. It’s not perfect. There is some rust at the seam where the rocker meets the pillar. The kickpanel area inside is non existent.
Old 01-22-2018, 11:59 AM   #9
Mack B
Mack B's Avatar
Originally Posted by MikeG. View Post
Dash ?
It’s got rust in the corners
Old 01-22-2018, 12:01 PM   #10
Mack B
Mack B's Avatar
thanks
Absolutely!
Old 01-22-2018, 03:09 PM   #11
pimpston65
pimpston65's Avatar
thank you for the photos. shes a bit too rough for my project...
Old 01-22-2018, 03:57 PM   #12
Mack B
Mack B's Avatar
I figured they would be, believe it or not this was a nice truck 20 years ago.
Thanks for your interest either way!
Old 01-22-2018, 08:30 PM   #13
jasons
not enough hours in the day
jasons's Avatar
I'd take the center section of the dash. How much to ship to zip 68924?
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
& piles of spare parts
jasons is offline   Reply With Quote
Old 01-22-2018, 10:34 PM   #14
Mack B
Mack B's Avatar
While not completely hacked up, the radio hole has been trimmed about an 1/8” see pic. If this isn’t a deal breaker tell me how much of the dash you want and I’ll get you a quote.
Old 01-22-2018, 11:16 PM   #15
DPowers
DPowers's Avatar
So the one on the cab and the one in the floor of the cab are the same?
I may still be interested pending pics when you get the time.
My email is dwanepowers@att.net if that is easier.
Old 01-22-2018, 11:47 PM   #16
Mack B
Mack B's Avatar
No sir, the one in the cab was the earlier style and someone cut the portion that wraps around the cab off....with an axe it appeared I couldn’t find it but pretty sure it’s been recycled.
The passenger side one is in better shape than I remember. It’s straight, but does have pretty deep scratches around the bottom. $30.00+shipping?
Edit: I’m wrong there was a third sail panel, that was different and butchered. The one in the cab was the right style but was cut up as well....still gone eitherway.
Old 01-23-2018, 12:18 AM   #17
DPowers
DPowers's Avatar
Thanks, but the best I could do would be $25.00 shipped. If the rectangular brackets that are on the cab are there, I would do go $30 shipped for the brackets and the one sail panel.
Old 01-23-2018, 12:19 AM   #18
ScottH
ScottH's Avatar
would u b willing to cut out & ship the center hump?
Old 01-23-2018, 12:37 AM   #19
Mack B
Mack B's Avatar
Yes sir, the pic didn't show up as sharp as I hoped. The area under the gas pedal has rusted through, the passenger side is soft in that area as well. If those areas don't matter to you, just show me where you want it cut.
Old 01-23-2018, 12:41 AM   #20
Mack B
Mack B's Avatar
I need the brackets for my project, but I will get the panel to your door for $30.00
Old 01-23-2018, 12:54 AM   #21
ScottH
ScottH's Avatar
Appreciate ur help on this. The easiest way would be from the open seam to where it ends under the seat. On the sides if u could cut it where it meets the flat floor area on both sides that should work. LMK if that isnt clear & what u need for the patch.
Scott
Old 01-23-2018, 03:20 AM   #22
aotte1
Interest in big back window section, condition and pics of it.
What price do you want?
Les
aotte1 is offline   Reply With Quote
Old 01-23-2018, 07:35 AM   #23
MikeG.
I want the Whole dash from door to door
Old 01-23-2018, 09:22 AM   #24
fredhlynch2
Need bracket and pedals for the brake and clutch. Zip code is 54935
fredhlynch2 is offline   Reply With Quote
Old 01-23-2018, 09:37 AM   #25
jasons
jasons's Avatar
I think I can work with that. I'd take from the instrument panel opening to the glove box opening and a few inches on the top. Kind of like this, a couple more inches to each side would be good.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
