Old 01-24-2018, 02:10 AM   #1
mfm3
Sound deadener in the cab corners...?
Removed the in-cab tank and now swapping out the carpet. Looking for advice on what to do with the inside corners. Should I use sound deadener mat in this area or are there better options? Also wondering if there is any reason not to add sound deadener to the back wall of the cab. I have a piece carpet that will cover the back wall.
Would also like to see ways to make the space behind the seats usable for storage, although I don't know what I would need to put behind the seats. Maybe a set of jumper cables, fire extinguisher, small toolbox, etc.
mfm3 is offline   Reply With Quote
Old 01-24-2018, 03:41 AM   #2
wahl4m
Re: Sound deadener in the cab corners...?
maybe if the cab corners are non-rusty ?? id spray w/ bed liner or undercoat ?
wahl4m is offline   Reply With Quote
Old 01-24-2018, 10:54 AM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I would not stuff sound deadened down there myself. I would put some on the back wall tho. Good luck!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-24-2018, 11:10 AM   #4
vin63
It's Better With Nitro
vin63's Avatar
I used sound dampening mat in the corners. I did treat any rust in the area before hand.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
