02-02-2018, 05:55 PM | #1 |
Steering column wiring
Have you fellas that have added cruise with the blinker switch been able to run the wires down through the inside of your column? The innards of the steering column have always been something that I try to stay away from, but I don't wanna run this cruise wire on the outside of the column if I can help it.
1972 GMC Jimmy 6.0/4L65 1972 Chevrolet long bed 1/2 ton |
02-02-2018, 06:33 PM | #2 |
Re: Steering column wiring
Yes, it does fit, but you will want to run it through the metal chase under the column
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
