Old 02-18-2018, 03:53 AM   #1
fredhlynch2
Gas Pedal Options
I have given up trying to find a 71 - 72 C10 gas pedal for my 64. They just are not out there.
What have other folks used instead? Lokar perhaps? Some other brand? I have a Lokar cable but have not installed yet.
Thanks for the help.
fredhlynch2 is offline   Reply With Quote
Old 02-18-2018, 06:52 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Gas Pedal Options
I have a 72 I am going to use.
But I can see why either of these couldnt be used:
https://www.ebay.com/itm/1972-82-cor...daci5F&vxp=mtr
https://www.ebay.com/itm/1972-73-74-...5ZUHLO&vxp=mtr
Old 02-18-2018, 08:54 AM   #3
73-87 should be same pedal/linkage setup as the 71-72. That may give you some more options.
Old 02-18-2018, 02:04 PM   #4
64shortbox
64shortbox's Avatar
I think the Corvette gas pedal assy Rocknrod posted would be your best bet. I ended up using a pedal assy from a 75 Pontiac but had to heat & bend it to make it fit properly then used the plastic pedal from a 73 or so Nova.
Here's what I started with a brake pedal from a 73 C-10 and a gas pedal assy from a 75? Pontac. Here's what I ended up with after I heated & bent the Pontiac gas pedal & added the Nova gas pedal. You can see my heat & bend areas on the gas pedal if you look closely. Next up is the stainless pedal trim used on GM cars from around 69 to 74. After that I'm getting rid of the E brake pull handle assy and adding a floor E brake assy from a 72 Caddy.
64shortbox is offline   Reply With Quote
Old 02-18-2018, 10:26 PM   #5
fredhlynch2
Thanks Rocknrod! I'll go with the 72 Corvette pedal assembly. I think I can make that work.
Old 02-19-2018, 02:22 AM   #6
DLW
I went with a Lokar pedal assy. for a 67-70 C10.
DLW is offline   Reply With Quote
Old 02-19-2018, 11:01 AM   #7
wcstory
wcstory's Avatar
On my 1966 GMC 2500 2wd I used a 73-87 assembly to replace the floor mounted pedal with rod linkage.
The 73-87 pedal is attached to a larger bracket assembly. I trimmed off everything but the pedal mount.
1966 GMC 1 Ton 305 V6 SM420 4 speed - retired Fire Dept Support Truck from Little Falls, NJ
My GMC Photos
wcstory is offline   Reply With Quote
Old 02-19-2018, 11:10 AM   #8
CANUCIT
CANUCIT's Avatar
DLW that pedal assy looks good
that's exactly what I am looking for
thanks Michael
1962 chevy short and wide
2015 z71
1967 SS Chevelle
CANUCIT is offline   Reply With Quote
Old 02-19-2018, 12:32 PM   #9
scoot_mcgrute
I also went the 73-87 route on mine. Got it off of Ebay and it works great
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 02-20-2018, 12:14 AM   #10
maydaymike
maydaymike's Avatar
I used one from a '95 C-1500. I had to bent the arm where the cable attaches a little, and i welded a small segment of tubing onto the pedal end to form a curved shoe that the stock floor mounted pedal could ride on without binding. It's worked pretty well for over a year now.
maydaymike is offline   Reply With Quote
Old 02-20-2018, 01:20 AM   #11
steven03
I just bought a 98-2003 s10/blazer gas pedal off ebay for 15 bucks. Haven't mounted it yet but from just holding it up to the firewall in my 65' it looks to me like it will fit like it was made for the truck. I will post some pics this week when i get it finished up
steven03 is offline   Reply With Quote
Old 02-20-2018, 08:11 AM   #12
PGSigns
PGSigns's Avatar
I used an S10 from the junk yard.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-09-2018, 12:43 AM   #13
60apache
60apache's Avatar
olds intrigue
60apache is offline   Reply With Quote
