Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 02-20-2018, 12:21 PM   #1
Gypsyman
Need help identifying this rear axle...
I've been browsing for a disc brake front and rear set-ups to swap into a '63 C60 that I brought home and I ran across an odd combination that I don't seem to be able to identify.
The seller claims that both the front and the rear came from a mid 1980's GMC P35. Possibly an old Matco truck. Lug pattern is the standard 5 front - 10 rear that you would expect. The front looks like a regular step van A-arm setup but the rear is not what I'm use to seeing in this application. It a HD, front drop out, square tube axle like my small Internationals have. I'm hoping that the tubes are stamped with some kind of identification but I haven't been able to see the items in person yet.
The center chunk has the following markings...
JES3891
5 43
That's about all that's legible. I'm assuming this indicates a 5.43 gear ratio but I can't find anything regarding the JSE3891 marking.
Richard
Richard
Gypsyman is offline   Reply With Quote
Old 02-20-2018, 12:42 PM   #2
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Re: Need help identifying this rear axle...
Looks like a Rockwell C100 axle, I did a brake job on a 1990 HD 3500 with that axle and the pads were the same for the front and rear, brake code was JF9. It had an ID tag on the axle tube somewhere from what I remember.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
