04-19-2018, 11:38 PM | #1 |
Bagged pics without a C Notch?
Anyone have a bagged truck with the stock bed floor height and no c notch? I'd like to see how things would sit if I were to bag mine and if it's even worth it. Wheel size isn't too important right now but I'd be running either 17's or 18's
04-19-2018, 11:54 PM | #2 |
Re: Bagged pics without a C Notch?
You just flat can't get that low without some sort of notch no matter if you use springs, bags or coils. You can slide under the truck and measure the distance between the axle and the frame rail and between the center section of the axle and the bed and then go out and measure what the max drop would be bottomed out. Mines isn't that low but it bottomed out on the left rail so much it cracked the rail over the axle.
I'm actually looking at some sort of auxiliary bag setup on the rear that will serve to maintain ride height when I either have stuff in the back for a trip or tow a tear drop trailer. That probably won't happen unless I find I need it though. I've had several Cadillacs with the load leveler setup on the back and it is pretty nice to have it level it's self no matter what the load.
04-20-2018, 12:24 AM | #3 |
6" drop in back had to notch
build thread zenchal26 project 57 |
04-20-2018, 03:04 AM | #4 |
It's surprising how little rear axle clearance you can get away with. I had a Model A with just 1-3/4 between rear axles and frame and it only touched the snubbers once in five years. On my 51 panel I temporarily had under two inches differential-crossmember clearance before I modified the crossmember; I bounced the rear with all my might and never could make it touch - and that was with no shock absorbers.
Heck, run it low without the C-notch and see what happens. |
04-20-2018, 08:16 AM | #5 | |
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
04-20-2018, 09:53 AM | #6 |
Mine has no notch in the frame. Here it is with no air in the bags sitting on the bump stops and it has about three inches to the bottom of the running boards. It is running on eighteens and has a tire diameter around twenty seven inches. No modifications to the bed floor either, but the IRS diff bolts that hold it in are right up against the wood on the bed
The issue here is 'running down the road' or 'sitting'. At ride height, the running boards are about a beer can's height off the ground. The bag setup on mine is for ride comfort and adjustability, not to see how low it will go running down the road. If you want to run down the road at three or four inches off the ground I think you are going to need a frame notch. An IRS instead of a live axle might let you side step raising the bed. Just my two cents |
04-20-2018, 08:48 PM | #7 |
Thanks guys that's the info I was looking for. I don't really plan on having it that low while driving, I mostly just want to to lay out a little lower while parked at shows and such. Since the truck is "done" I was hoping to avoid notching and/or raising the bed floor. 3-4 inches off the ground would be plenty low for me
