04-23-2018, 10:26 PM | #1 |
What's my drop?
Hello, I have always wondered how much my truck is lowered. The paper from the previous owner said the front is lowered with 2 inch drop spindles and 2 inch springs, and the rear is lowered with 6 inch springs. So is that a 4 and 6 drop or am I totally translating it wrong? Any help would be appreciated.
68 C10 long-fleet, Long and low is the way to go. factory: 307 sbc, SM465 4-speed, 12 bolt 4.11 rear end. 75,000 original miles. Build:Ole Blue Millennial and can drive stick. "Too many people have opinions on things they know nothing about. And the more ignorant they are, the more opinions they have." -Thomas Hildern |
04-23-2018, 10:48 PM | #2 |
Re: What's my drop?
Yes, you are correct. That would be a 4/6 drop.
1970 SWB Build |
04-23-2018, 11:25 PM | #3 |
Re: What's my drop?
Thanks for the reply. Am I correct in understanding that is as low as you can go without cutting and modifying stuff?
04-24-2018, 08:22 AM | #4 |
Re: What's my drop?
Do you have disc brakes on the truck? Your description makes it sound all original, but there are no drop spindles for drum brakes. Do you have a side shot of your truck and what is the wheel/tire combo?
04-24-2018, 08:30 AM | #5 |
Re: What's my drop?
Yeah it has disc brakes. The description in my signature only states the factory drive train. My thread about the truck states all the stuff that has been modified. The wheel and tire combo are also listed there along with pics of the truck from all angles. I can post a pic here if you want though.
04-24-2018, 08:47 AM | #6 |
Re: What's my drop?
Pretty much. Your next step would be a c-notch in the rear and then you could maybe add drop blocks but you'd be really low out back at that point and would most likely bottom out quite a bit. Up front, you could switch to 2.5" spindles and 3" springs and that's about as low as you could go without needing to pull the inner fenders out.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
04-24-2018, 09:14 AM | #7 | |
Re: What's my drop?
04-24-2018, 04:03 PM | #8 |
Re: What's my drop?
Not to hijack the thread, but can you estimate the drop on my truck from the picture? It has 18" wheels with around a 27" tire.
I am going to make some changes to the front suspension and was curious at what the previous owner did...
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914 1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161 |
04-24-2018, 04:40 PM | #9 |
Re: What's my drop?
I don’t mind. Nice truck man. Honestly it looks pretty close to mine, maybe a little higher in the rear. Hard to tell from different angles. Might be my bumper or your wheel/tire combo as well. But it could be any combo of different parts giving you the drop, 2” or 2.5” drop spindles and different front coil length, 1” or 2”rear lowering blocks and different coil lengths. (Assuming you have 4 corner coils.
04-24-2018, 04:49 PM | #10 |
Re: What's my drop?
This might be a better picture to compare:
04-24-2018, 05:06 PM | #11 |
Re: What's my drop?
A lot of people cut the rubber bump stops in half on the rear of a truck with 4/6 drop. Gives just a little more room to haul stuff.
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom) 1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK. 1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive ! |
04-24-2018, 05:46 PM | #12 |
Re: What's my drop?
Did not know that. I’m going to have to check mine out now. Thanks for the info.
04-24-2018, 07:20 PM | #13 |
Re: What's my drop?
Yeah, I'd agree. 4/6
Just curious, did they relocate the rear shocks when they dropped it 6" ? If not, man your ride quality is suffering bad. Some $39 relocation brackets will make it ride like a caddy. Post a picture of it from the back, laying under the truck so we can see the rear axle and I'll tell ya..
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
04-24-2018, 08:15 PM | #14 | |
Re: What's my drop?
04-24-2018, 10:05 PM | #15 |
Re: What's my drop?
This is a 2/4 drop.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
04-24-2018, 11:25 PM | #16 |
Re: What's my drop?
I really like that color combo, looks amazing. That’s like in my top favorite 71-72 models I’ve ever seen.
