04-26-2018, 06:10 PM | #1 |
Aftermarket doors
Any one have info on new doors? I want to know do the look like the original with all the seams and such and how do they compare to originals in materials...
04-26-2018, 08:54 PM | #2 |
Post Whore
Re: Aftermarket doors
short answer is don't....unless you have no other option...original doors are much easier to make work.....repop doors almost always have to be reworked to fit...
04-26-2018, 09:10 PM | #3 |
04-26-2018, 09:12 PM | #4 |
I have 2 laying around. PM me if you want some pics. They are not perfect but they are original.
04-26-2018, 09:30 PM | #5 |
04-27-2018, 12:26 AM | #6 |
I got repos doors on mine.
04-27-2018, 01:16 AM | #7 |
04-27-2018, 07:55 PM | #8 |
04-27-2018, 07:56 PM | #9 |
04-27-2018, 07:58 PM | #10 |
04-27-2018, 08:20 PM | #11 |
That looks nice! Did you have to fiddle fuc@ around with it a ton? Mine are all rotten and I am looking for a donor or maybe these? Where'd you get em?
04-27-2018, 08:24 PM | #12 |
To tell you the truth. I did not do anything with them. You can see a little bit of a gap. By the gas cap. I dont care its not a show truck. They are good for me.
04-27-2018, 08:49 PM | #13 |
can you post a closeup of the door bottom seam where the inner and out shell is crimped?
04-27-2018, 09:03 PM | #14 |
04-27-2018, 10:17 PM | #15 |
I also used aftermarket doors on mine, The doors were the best fitting pieces of aftermarket sheet metal I used. Mine to is not a show truck, I drive it. The only issue I had was the aftermarket strikers took some work to make fit. The repop fenders both inner and outer, and a grille surround I had to drill out spotwelds on them to make them fit. The doors just bolted on.
04-27-2018, 11:52 PM | #16 |
i have a few originals im looking at, but im really thinking just pull the trigger on the aftermarket doors. it will save time fixing any issues on the originals.
04-28-2018, 12:02 AM | #17 |
What are the old doors going for? How do they ship them?
04-28-2018, 08:03 PM | #18 |
depends on finding them first, then how much work they need plus shipping. skys the limit. the limit does start at zero so it varies. shipping can vary also. a lot of luck with hours of searching is my go to.
04-29-2018, 12:54 PM | #19 |
04-29-2018, 03:30 PM | #20 |
04-29-2018, 08:07 PM | #21 |
Dumb question , which is easier , mount the hinges on the door then bolt to the cab or bolt the hinges to the cab then to the door . My doors have been off for many years , just about to bolt my reproduction doors on for the first time .
Thanks |
04-29-2018, 08:14 PM | #22 |
What you said first.
