04-29-2018, 07:15 PM | #1 |
cable pedal
what are you guys doing to switch to gas cable pedal? i am looking for something that is minimal fab work as i dont weld. i do have buddy that can do some welding for me.
04-29-2018, 07:56 PM | #2 |
Re: cable pedal
I used a pedal from 67 to 72 and got it here off the parts board. easy swap.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-29-2018, 08:12 PM | #3 |
Moderator
Re: cable pedal
A few people have done this with success: http://persh.org/Pickup/CableThrottle.htm In fact thats what I am now doing.
'71-'72 or '73-'87 pedals should work. Although I havnt seen it done I even think the Lokar Xbag will work (see post #8 below) - https://www.ebay.com/itm/Lokar-XBAG-...mtr&rmvSB=true Lokar Pedal - http://67-72chevytrucks.com/vboard/s...51&postcount=4 They also have an 'Eliminator' floor mounted pedal.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 05-04-2018 at 01:15 PM. |
04-29-2018, 10:34 PM | #4 |
Re: cable pedal
I believe it’s a lokar assembly. I used a chunk of billet to offset the pedal. So much easier to pedal now.
At my worst I'm at my best |
04-29-2018, 11:18 PM | #5 |
Re: cable pedal
I dont have a pic but i used a s10/blazer gas pedal i got off ebay for 15 bucks. fits almost perfect just drilled a couple holes and bolted it right up.
04-30-2018, 11:34 AM | #6 |
Re: cable pedal
I used a mid 90's suburban pedal in my 62. Super simple and dirt cheap from the junkyard. Just trimmed the right side down a little, drilled three holes and bent the rod to where I needed it to be.
05-01-2018, 10:22 PM | #7 |
Re: cable pedal
I used the gas pedal assy from a mid 70's Pontiac. The plastic gas pedal came off a mid 70's Nova. I did have to tweek (bend) the Pontiac gas pedal assy a little to get everything to work correctly. Nothing a vise couldn't handle. I also added the Power brake pedal from a 73 C-10 and next on the list is the stainless trim kit for a Chevelle to finish off the look.
Another item I plan to add is an emergency brake pedal assy from a 72 Caddy so when I drop the truck into gear - Drive or Reverse the parking brake will release automatically. Yep, I'm lazy and forgetful. |
05-04-2018, 12:44 PM | #8 |
Re: cable pedal
I just went with a Lokar pedal for the 67-70 C10, put it where I wanted and drilled 3 holes.
05-04-2018, 09:55 PM | #9 |
Re: cable pedal
Where did you get your fire wall cover?
05-05-2018, 12:27 AM | #10 |
Re: cable pedal
05-07-2018, 10:17 PM | #11 |
Re: cable pedal
05-07-2018, 11:31 PM | #12 |
Re: cable pedal
