05-01-2018, 11:04 AM | #1 |
Vehicle Speed Sensor
I removed my cluster & noticed what I think is a Vehicle Speed Sensor attached to the speedo. (See pic)
What does this do? Would it by chance have anything to do with the cruise control? If so, I know longer have the cruise hooked up. Can I remove this part? |
05-02-2018, 03:29 PM | #2 |
Re: Vehicle Speed Sensor
Depends on year of vehicle I'd guess. It's an optic eye mounted to back of speedo to determine your speed for the cruise control and I believe the computer (if equiped).
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
05-03-2018, 06:54 AM | #3 |
I don't have any plans on finding all the parts needed for the cruise control.
So I guess this can be removed.. |
05-03-2018, 06:44 PM | #4 |
I don't know the year of your truck, but my 83 with factory cruise control has a VSS in the speedometer cable going to the transmission. It is a two piece cable (short cable and long cable) with the VSS in between the two cables. I suppose there might be something like you picture in my truck, but I don't recall seeing it the last time I had the dash apart.
