05-01-2018, 07:19 PM | #1 |
T5 Transmission and Reverse Lights
Hey guys, working on getting my reverse lights working on my 66 and am in need of some help. I have a T5 transmission and I re-routed the factory reverse light wire to the switch on the transmission and then back to the lights. I thought it may be a switch but a new switch has netted the same results. I tried grounding a light directly to the frame last night but still didn't get anything to come on.
Anyone have any insight on how to get the reverse lights working with a T5 transmission? |
05-01-2018, 07:22 PM | #2 |
Re: T5 Transmission and Reverse Lights
I should add that the reverse lights are new from LMC and the truck originally had a 3 on the tree.
05-01-2018, 07:43 PM | #3 |
Post Whore
last time I had mine not work it was the harness side plug that was bad....if you can check it there see if its working..
05-03-2018, 03:00 PM | #4 |
I bought aftermarket lights for my 64 and the socket is junk. I have to wiggle the bulb to come on and had to wedge a piece of wire in to get contact. I ran mine from the battery and not through the ignition so I need to remember not to leave the car in reverse when I park it.
05-03-2018, 08:07 PM | #5 |
Make sure they are grounded well. That was my problem T5 reverse lights not working.
Never drive faster than your Guardian Angel can fly Larry |
05-06-2018, 09:01 AM | #6 |
Do you have voltage at the taillights or the switch?
Are the new lights LED? If so they may be connected backwards. |
