![]() Join Date: Oct 2012
1965 c10 under hood wiring diagram
Does anyone have a good wiring diagram for the under hood wiring
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
![]() Join Date: Jan 2011
Re: 1965 c10 under hood wiring diagram
Look in The FAQ section. Plenty on the wiring and just what you need.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Thanks!!
Scrapper 1
best thing to do is go buy the re pop Engine harness and front head light harness from carandtruckshop.com.
Its a plug and play system spend the 50-150.00 for the hood blinkers harness an thevoltage and front head light harness then they have the engine harness that dose the temp the starter and HEI wire or points distributor. Its a plug and play system you do it any other way plan to spend a lot of time on the side of the road |
^ no.
I started out with nothing - and I still have most of it |
