05-05-2018, 09:21 PM | #1 |
Front drive shaft 82 K20
I rebuilt the front drive shaft and neglected to keep track of the order of the parts. I now have an out of balance shaft. Any hints as to what to do. I could make note of the order of the parts now and take it apart and try different clocking. Is there some way to figure what is right other than trial and error? Thank you!!
05-05-2018, 09:25 PM | #2 |
Post Whore
Re: Front drive shaft 82 K20
what do you mean by order of parts...should be 2 or 3 u-joints[3 if you have a cardan joint], and the slip joint....make sure you have your yokes phased correctly...out of balance/vibration probably caused by this....
https://www.youtube.com/watch?v=DDmz0tibVGM shouldn't be a big issue on front d-shaft unless you have fulltime 4x4 or run it in 4wd at rd speed....but it needs to be right
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-05-2018 at 09:32 PM. |
05-05-2018, 10:53 PM | #3 | |
